[4]
Home Made Gears
[3]
[10] Like what you see?
john9
Newbie
Jun 16, 2014
13
Hi, I haven't posted for a while since I finished the Bolton #12 I decided to
go back to the first engine I started to build and never finished, an Elmer's Geared (Hypocycloidal) Steam Engine, it was never finished because of the internal gear that is required, I ordered one from Boston gears USA(big dollars)but they sent the wrong one, external instead of internal so I moved on, now I want to show my setup for cutting internal gears also some bevel gears for the Bolton#12,
I made the internal gear with a single point cutter mounted in a shaper, to get the correct profile cutter I cut two teeth from an involute circular cutter and ground it down to one tooth with a square stub to mount in the end of a rod mounted in the shaper, the involute cutter cost $15 and you can get about 6 single tooth cutters out of it, it worked out well, some photos of my gear cutting,
John.
turnitupper
Active Member
Aug 12, 2014
237
Credit where credit's due. I think that idea of chopping the involute cutter up is bloody brilliant!
John.
brino
Jan 2, 2014
3,744
Nicely done!
-brino
FOMOGO
H-M Platinum Supporter ($50)
Sep 2, 2013
2,023
Great job. So basically using that single tooth as a broach. How many passes were required to produce each V to full depth? Mike
Silverbullet
Gold
May 4, 2015
3,482
Thinking outside the box, way to go . Where there's a will there's a way. Nice set up for the shaper , old time gear cutting . Oh to hear the old overhead gears clanking and grinding when put under a load. Man am I old ,remembering working with mills ran by big old flat belts slapping , a rewarding time now I think of it , but oh my god the work was exhausting .
ogberi
Oct 20, 2014
494
Is there a difference in tooth shape between internal and external gears? How does the number of teeth and cutter number correlate on internal gears? Great idea, though! Never thought to chop up a gear cutter to make single point cutters. +1 for thinking outside the box! Or is it thinking inside the gear?
Tony Wells
Platinum
Jan 22, 2011
7,069
The difference is essentially the Addendum allowance between the internal and external gears. In simpler terms, the pitch circle difference or clearance between running gears. If you are making a mated set, no problem, you're cutting to fit. If you are trying to make spec gears, then you need some rather odd instruments to measure the tooth thickness at the proper depth.
ogberi
Oct 20, 2014
494
That is about what I thought. I need to break out some thin plywood and the scroll saw and make a solid model to wrap my head around it properly. I imagined a rack curved into a circle with the teeth on the inside.
john9
Newbie
Jun 16, 2014
13
Hi Fomogo, this cutter was for an .5 module 72 tooth gear so the size of the tooth is quite small,
the depth of cut for .5 module is 1.08mm or 42 thou and the material of the blank was aluminum
even so I made the cut in about 6 steps as the shaper was running at about one cut per second I just
wound it down a few thou each stroke using the indicator to measure the depth,
John.
gbritnell
Mar 22, 2013
188
Very ingenious use of tooling. I'll certainly remember this one.
gbritnell
wagnmkr
Active Member
Aug 7, 2013
29
Very Well Done, and an excellent example of "Just Getting It Done".
Tom
RIMSPOKE
Active Member
Jan 16, 2016
288
I USED TO MAKE CUSTOM GEARS THAT WENT INTO IBM PRINTERS .
HERE IS ONE I MADE FROM A PENNY JUST PLAYING AROUND ON THE MACHINES .
I MADE A COUPLE DOZEN OF THESE FROM OLD WHEAT PENNIES & SOLD THEM TO COIN COLLECTORS .
THEY CLOSED THE SHOP & I WOUND UP OWNING SOME OF THE EQUIPMENT .
HERE IS MY MAHR ROLLING GEAR INSPECTION MACHINE . IT's ONE OF THE BEST & SOMETHING THAT I NEED TO SELL .
I ALSO HAVE A SET OF PRECISION MASTER INSPECTION GEARS
AND SEVEN SETS OF 8 GEAR CUTTERS , MOST NEVER USED . IT ALL NEEDS TO GO .
[5] [7]
