- Mar 3, 2020
- 195
I made this slitting saw arbor with a 1" arbor and 3/4" shank from 1.5" 1018. The largest diameter is about 1.470" after cleaning up.
In-progress... tapping for 3/8-16. I'd have used fine-thread but I had these screws and it shouldn't matter for this application.
I need to pick up some boring bars. I made one to get by, out of a 1/4" HSS square bit. One hole started 1/2" and was bored to 1.001" to slip over the arbor, and one started as 15/64 and was bored to 0.600" to countersink the screw.
It's a bit tall below the cutter.... this is because I made it so I can install a blade up to 7/16" thick. Probably a bit overkill since my current mill is a Grizzly Mini Mill. Though I figure it's easier to face more off than it is to add material back
