I finally got a VFD and wired up my Republic surface grinder, and as part of my check out procedure I tested for the presence of AC voltage with one of those non-contact AC sniffers. To my surprise, the entire chassis of the grinder was hot, but I can't find a DC leakage path with a multimeter, so I'm scratching my head.
I have split 220 (L1 + L2) going to the VFD through a double throw switch. The 3 phase is wired directly from the VFD to the motor. The Republic uses a lot of plastic bits to insulate the electrical boxes/conduit/etc from the chassis, so that the original 3 phase power cord was grounded to the junction box and the motor connection box, but NOT the chassis.
I'm using an extension of the house drier circuit to power all the 220 machines in my garage (always one at a time). I have an identical setup with VFD on my Nichols mill, but it doesn't have the same problem. Neither machine is grounded because the drier circuit has a separate issue that needs to be fixed. Please don't tell me it's unsafe to run this way. I know it is, but it's an old house.
I can't find a current path from the 3 phase wiring to chassis using a continuity test or even low and high (10 meg) resistance test. Yet the sniffer tells me 90V+ AC is present. I even tried hand turning the spindle but that made no difference. If it was a problem with dirt/contamination, I would think the high resistance test would pick it up. The motor is sealed, and the motor junction box is clean. The grinder and VFD otherwise work flawlessly. I'm tempted to ground the machine to the neutral lead, but that wouldn't explain what's going on.
Suggestions?
-Dave
Suggestions?
-Dave
