- Nov 23, 2014
- 2,606
How about band sawing slightly long, then face one side on the lathe. Then go to the mill and mount them vertically in a V-block and dust the opposite side to length. Only problem I could see with collets and a stop is you have to make sure you draw the collet in the same depth each time. Turn a little tighter or have a slight variation in diameter your length will be slightly off. Might be within your tolerance as I'm really splitting hairs here.
Bruce
Bruce
