Yeah i saw the linkage but my perspective was wrong. I thought it was seeing the table move and the mill head was in a fixed position. I see you're right. Makes a lot more sense.Looks like the table is not moving, but he is using the rotary table to turn the mills head on its column, to get the right radius on the tooth cut. Watch right at the end, and you can see the linkage off the tube mounted to the rotary table he is turning, and it is moving the mills head. Then after the tooth is done, he indexes the rotary table the gear is mounted on to get the next tooth in line. Wish it was a longer video, but most of the action is at the end.
Intriguing.
