Hi all, sorry my first post is such an oddball question.
I work out of borrowed space. My landlord lets me use his work space provided I don't cause problems, so all my tools need to be portable. I store my tools up a flight of spiral stairs. In short, my first lathe needs to be light enough for a single person to lift up stairs. I'm guessing 60lbs is the max I can lift in one trip safely.
I was reading about the micromark and littlemachineshop 7x16 lathes, and see that they're about 90lbs. How much weight could be removed? I imagine I can make a separate trip for the tailstock and chuck, which I'm guessing would together be about 15-20lbs. Can the carriage also be easily removed?
And lastly, how much of a pain will it be to re-align the lathe after disassembly and reassembly? More than 30 minutes of fiddling?
If you have other suggestions that don't involve a 7x16 lathe, I'm totally open minded here. Just trying to figure out what could work and what won't work before I make any decisions.
Thanks!
Thanks!
