[4]
How to attach a Palmgren 250 Vise to my PM1022?
[3]
[10] Like what you see?
Capt45
Active Member
Jul 15, 2017
56
Is it possible to attach a Palmgren 250 to the carriage of my PM 1022 in order to do ome ight milling? And if yes, please explain the procedure..
Thanks in advance.
ttabbal
Brass
Jun 12, 2017
966
You can probably adapt it, but I don't think it would mate up directly. You would probably be better with a flat bottom attachment using the t-slots on the carriage.
ch2co
Grumpy Old Man
Jan 9, 2013
985
I got a little 2”? Palmgren lathe milling adapter in a box of you name it shop tools that I got with my little used
10-22 lathe. Took a bit of time to figure out what it was. It just bolts to the back section of the cross slide. I’ve never used it because I also got a little griz. Mini mill thrown in with the lathe. At the time I thought that that tiny mill couldn’t do anything anywhere near what I would need. I was wrong about that. That stupid cheap little mill can do a heck of a lot more and better than I could have ever dreamed. Still planning on getting an up sized one though. I’ll probably sell of the little milling adapter unless I find another use for it.
pdentrem
Jan 28, 2011
2,125
I made an adapter that uses the center bolt of the QCTP. One thing I had to do was to machine the top of the Palmgren base to get a nice flat top on it.
rwm
Mar 25, 2013
1,758
I drilled holes in each of the legs that lined up with my T slots. I believe I used 5 or 6 mm screws. Four of those into the slots keeps it very stable.
Robert
Capt45
Active Member
Jul 15, 2017
56
Robert
Like to see a pic of the setup if you have one. Thanks for the info Robert.
Capt45
Active Member
Jul 15, 2017
56
You have a pic of the adapter you made pdentrem? Sounds like that's what I might need to do. Appreciate the info.
pdentrem
Jan 28, 2011
2,125
As you can see, the adapter is a simple tube. It has a base that is slightly shorter than the height of the Palmgren base, a flair area to straddle the base legs and a reduced diameter tube to reach high enough to use the QCTP nut. The legs on the Palmgren is machined a flat surface for the adapter to sit on properly. Depending on the height of the top slide, some kind of spacer under the vice might be needed to raise the center point of the vice to the center line of the lathe, if so desired. On my lathe I have not the need to do so.
Pierre
Capt45
Active Member
Jul 15, 2017
56
Thanks again. You obviously have or have access to a mill for making the jigs. I have the PM 1022 and my imagination. I'll make it work.:)
pdentrem
Jan 28, 2011
2,125
Yes for the adapter for the Atlas lathe, I did use a mill for the relief areas. I also used a surface grinder to flatten the upper and lower surfaces. The newer tube version is much easier to make and use!
Capt45
Active Member
Jul 15, 2017
56
Did you mill the upper part of the Palmgren where the tube fits?
[5] [7]
