[4]
How to buy a shaper?
[3]
[10] Like what you see?
Glenn Brooks
H-M Supporter - Gold Member
Nov 14, 2014
779
Iam going to drive down to look at the small 7” Atlas shaper that’s been advertised on CL next weekend. I called the owner and learned he bought it to do a cosmetic rebuild and sell. Says he disassembled the machine and looked at everythng, but didn’t have to replace any parts. Also that he rebuilds old machine tools and resells them. Not a deal killer by any means. But to me, it means the seller doesn’t really know how the machine performs. So it looks very nice, cosmetically, but buyer beware.
My question is, are there some common inspection points I should look at with this style machine? Any key tell tale wear patterns to look for??
For example, I’ve learned to inspect the underside of the tailstock on a lathe, to feel for ridges or wear lines cut into the tailstock by the ways, as an indicator of overall wear...
But, have no experience with shapers, of any kind.
So just wondering if there are a couple of key inspection points to determine if the Machine is clapped out, or not??
Thanks much,
Glenn
Superburban
Jan 2, 2016
730
I'm not experienced by far. When I bought mine, I looked close at the ways for the ram, and table. And took a look at the gear teeth, and The ways for the big arm, in the big gear. And the last points I considered important were the bearing/ bushing that the big arm pivots on, and the bushings/ bearings ate the top end.
See if you can find a parts manual, or diagram for the Atlas. See where all the bushings are. Check those for play, to me they would not be a deal killer, but rather a bargaining point. But that is more determined by your experience, and tools you have to make things.
Downwindtracker2
Sep 5, 2014
411
The drive, which I've forgotten the name of, can get sloppy. BTW the Atlas shaper is well made. Better than other Atlas offerings.
Does it have the skate under the table? Does it have the vise? Shaper vises are different than milling machine vises .
Doubleeboy
Dec 3, 2014
769
Look for broken parts, shapers can be cruel to themselves when something goes wrong. Check all the parts of the scotch yoke for welds or brazing. I am no shaper expert but I did look at a number of little ones before buying a Logan.
Glenn Brooks
Nov 14, 2014
779
Thanks Doubleby, what is a scotch yoke?
F
f350ca
Guest - Please Register!
As has been mentioned check the ram ways for signs of wear. You'll see ridges at the top of the way on the ram if its worn bad.
Extend the ram out as far as it will go and check up and down slop with an indicator. More than a few thou could be a problem. Some can be removed by adjusting the gibs but uneven wear may make it tight in some spots.
Check if the table is parallel to the ram with an indicator. Mount the indicator to the tool post and run the ram back and forth. Excessive droop at the front means the ways for the table are worn.
On a small shaper you should be able to push and pull on the ram to check for wear in the block / yoke that drives the ram off the bull gear.
If he's "restored" it you won't be able to tell how much oil was used on it. These things have so many sliding and rotating parts that they need to be dripping wet to survive.
Other than wear in the ram anything else can probably be rebuilt or remade with the machines you have.
When I bought the Peerless it had sat for 11 years, it was so tight from the oil going stiff I could hardly turn it by hand on the motor shaft, but the ram looked good. Couldn't power it up so had to buy it as is. Figured at $400 for probably 4000 pounds of cast I could recoop most of my cost at the scrapers
Greg
Glenn Brooks
Nov 14, 2014
779
Greg
Thanks Greg, these items are going on my check list. Exactly what Iam looking for.
12bolts
Global Moderator
Apr 23, 2011
1,969
I managed to acquire a Douglas shaper in excellent condition a while back https://www.hobby-machinist.com/threads/my-new-ish-shaper.53313/
The clapper box has absolutely zero wear, or sideways movement that I can detect. I dont know if its a wear problem point for shapers generally, but I imagine it would be "easy" for a machine reseller to overlook that area. Loosen the ram position adjustment nut, (on top) and you should be able to slide the ram easliy but not "too freely" in its ways. Check the table advance gear for chipped/broken teeth. I managed to snap a tooth off mine easily. Stupidly! But still easily done...........
I didnt get a vise with mine, and as previously mentioned they are different, $pendy, and can be hard to come by.
Cheers Phil
vtcnc
Administrator
Staff member
H-M Platinum Supporter ($50)
Jun 29, 2014
438
Keep an eye out for patches of J.B. weld in the casting. While not necessarily deal breakers depending on the size and location of the patch, fresh paint by resellers is a sign they are covering something up.
Dabbler
Administrator Trainee
Staff member
Oct 11, 2016
838
Perhaps it is a bit basic, but in the thrill of the find, often overlooked (and I have several discarded remains of ignoring this). You can't ignore your instincts - if the guy feels shady, or the entire package looks or feels a little dodgy, it is a very good idea to walk! Sometimes it is just the overall look of the machine or what is missing (and you ask yourself "why would this be missing?")
If you love rebuilding machines as I do, you can forgive a bunch, as long as the deal and the machine are solid. I agree with vtcnc about repainted machines, a definite warning sign!
I recently bought a 1920s shaper from the 'here's the castings, now build it yourself' era of machine tools. it is a 6" storke 5" X travel shaper in very rough condition, but all the parts were there and the hard stuff: the gears, the scotch yoke, and the ratchet advance were in good shape. I'll have to replace a gibb, and is about a 200 hour project. But it is what I love to do, so I bought it.
Part of what to look for is what you feel you are willing to fix, or do you want a working machine? Do you have the budget for a perfect one, or do you have to go discount? Do you have the tooling, skills and time for a big project? In some ways these answers will dictate how picky you look at the machine.
In any machine tool I check fo cracks in the casting, looking in and out if possible. I look at the wear marks and chipped paint for signs of abuse. I try to look at what I can see of the ways to look for excessive wear due to non-lubrication. These things can scuttle the deal for me.
Glenn Brooks
Nov 14, 2014
779
Several people have mentioned looking for wear on the ways, with attendant drop in the tool post, cutter across the surface of the work.
Obviously, old tools are gonna have wear. But, How much wear is to much? (In thousands)
I plan on taking a dial indicator with me and measuring vertical movement of the clapper as the arm moves in and out.
One of the primary purposes I would use this shaper is to make dovetails. For mating surfaces, clearly flatter is better.
Thanks for all the suggestions thus far. Great primer on shapers!
Glenn
Dave Smith
Mar 10, 2013
1,088
it looks real nice but an odd color--I have two of them --one green and one orange--he is priced pretty high and for that price the tray and stand should be included---Dave
Doubleeboy
Dec 3, 2014
769
Lots of youtube videos showing scotch yoke movement. BTW that shaper is over priced in my book and to boot has fresh paint, which for me is always and I mean always a RED FLAG. Others love fresh looking machines, but fresh paint hides flaws as others have mentioned. Machines with soft ways are pretty easy to spot wear on, your fingernail can tell you a lot. Its fun getting excited about a possible new tool, but keep in mind Atlas were budget machines, not saying they can't make parts, but they are not heavy duty, used pot metal parts in places, do not have hardened slideways. Because they are small and can be moved easily they go for a premium for what they really are. If you want a better machine, looking for a Logan, Southbend or other would be a good choice.
If you have the space move up and buy a real machine that can work, something in the 12" or more size range. Shapers are great for cutting dovetails, but I can cut them way faster on a mill than I can on a small shaper and more accurately also unless that shaper is a tight, low wear machine. To me the reasons for a first shaper are..... you want one, its cheap and you have room or you have lots of keyways to cut. Myself I just wanted one, to this day I wish I had gotten a bigger one, mine works great, but anything I can do on it, I can do faster and better on my mill. If you just want one because they are cool, might want to consider one without the fresh paint and high price.
extropic
Nov 24, 2014
547
In addition to looking for braze/weld repairs, don't hesitate to question the seller about the subject. Remember, he's seen the machine BEFORE the refinish. If he's not ready to guarantee that there aren't any, I would count that as a significant negative. If there are such repairs, use your judgement.
Downwindtracker2
Sep 5, 2014
411
I have 6" shop built shaper that I'm completing, so I asked just how accurate are these things. To know when I'm there. It 's from the '50s I'm guessing. No one really gave me an answer. I have 4" Chinese milling machine vise I'm going to use on it. It was made on a shaper and it was .005" out. I think that might be the answer.
However lookcreations on YouTube has his really tuned up.
F
f350ca
Good question Glen. As for a number Im not sure. When the machine is running the ram should be floating on a layer of oil so ideally all the clearance is taken up. With that in mind probably 3 thou up and down movement with the ram retracted and fully seated in the ways of the base. With it sticking out that is going to be amplified. With say half the ram in the ways you'd then probably get 6 thou up down. Thats assuming your squeezing the oil film out. I've measured the movement on mine and can't remember the number, will try and remember to measure it after coffee. Old age thing.
Greg
tertiaryjim
Mar 3, 2014
616
I did some searching in Connelly's book and for new clearance in the ram a minimum of 5 tenths and maximum of 1.25 thousanths.
That was for flat ways so a dovetail might need more than 5 tenths. Don't know.
If it has several thousanths wear I would consider scraping it back to spec.
F
f350ca
The shaper is a lot tighter than I remembered. Forgot and had to go back out and measure.
With the ram retracted i could get .0005 movement up and down with all I could lift on it.
With an 18 inch bar i could get about 2 thou.
With 10 inches of ram out beyond the ways I could lift it about 0.001 by hand, hard lift
The 18 inch bar would lift it .0025.
Greg
Glenn Brooks
Nov 14, 2014
779
Thanks all for your info. Particularly measurements on ram movement. Really good to know.
Yep, Iam a little concerned by the new paint job and no info on how much variantion there is in ram movement, flatness of the dovetails and machine surfaces, etc.
Dave lives nearby and might be able to go take a preliminary look for me. (Around 5 hr RT for me, + time to inspect etc).
Shapers don’t come up around Seattle very often. Maybe 2-3 times a year. Sadly a 10” shaper just sold in Idaho. Didn’t get a chance to go see it, before it fell off CraigsList. Plus I don’t have any room in my shop until I sell some stuff. Plus Iam kind of tired of moving 3000# tools around. so a small one is attractive. Although, I bet a larger one would be more useful over the long haul. Just have to see how it plays out.
Glenn
Silverbullet
Gold
May 4, 2015
3,448
Don't forget slop in the shafts , gears shouldn't float , shafts shouldn't either . Push and pull Ck the table in all directions. The ram too. Engage and Ck the feed , no slip jumps or non movement. Wear on gear teeth there soft also.
francist
Sep 5, 2013
1,190
Now that everyone has piqued my curiosity, I went down and measured mine. It's an 8" stroke machine, and I think around 75 years old give or take.
With the ram at full stroke out, I can get 0.0015 vertical at the tool head. Just me lifting it, no bar or anything. Perhaps not so good is side to side at the same extension -- I can see almost 1-1/2 thousands each way.
I can tell there's some crowning or hollowing on the ways, it runs best in the mid-range, but if I snug the gibs any more it starts to tighten up.
For my uses it's still plenty adequate, but I also don't have tons of time on it.
Good luck if you do chase it, Glenn. It's sure nice looking, that's for certain.
-frank
tertiaryjim
Mar 3, 2014
616
It seems to me that as the ram gibs wear people find it wont cut true and then machine the table top flat to the ram travel.
Might want to check that the table has plenty of meat left.
cjtoombs
May 10, 2012
663
One thing about Atlas machines, they typicaly didn't get much use, so I would be surprised if you see any signifigant wear on it. They were sold as hobby machines and not many were used in industrial settings, which is where you tend to get a lot of wear. Galling on the ram ways would be something much more common, which is caused by insuficient lubrication. I have one of these shapers, and it's a good little machine for it's size. I use it occasionaly for small jobs. I wouldn't let the zamak parts used on Atlas machines scare you off, many of them have lasted for 50 years and if treated well (not crashed or dropped) will last another 50. As stated above, having the vise on it is goodness. Those Atlas shaper vises come up on Ebay occasionaly, but they generaly sell for around 250, so take that into consideration if it doesn't have one. They also made a rotary table and index centers for them, but they tend to be fairly rare and expensive.
C-Bag
Ned Ludd's bro
Feb 9, 2017
677
I'm with the rest of the guys, cosmetic paint jobs are a red flag. I see buying machine tools like buying used cars and a paint job was always a bad sign. It usually meant they'd rather look good than work good.
Mine suffered from bad adjustment by careless operators. Like the cutting head gib had a HUGE gouge in it that made it so it wouldn't operate its whole range. This also had warped the gib. I suspect it was somebody over tightening the gib but who knows with a machine this old. Several suggested by its paint job that it was a school machine. It also had .005 up and down play in the ram. For some unknown reason it had an extra shim under one side of the ram. When I took it out and checked it had .0015 play retracted and less than .001 extended. I'm sure it spent most of its life cutting small things in close and in the middle of the X range. The X nut needs replacing and probably the X lead screw. The insides looked good but the ram adjusting screw had obviously been jammed also. Probably someone not taking the lock off first. I straightened it and it works fine now. This also happened to to stroke adjuster. The screw itself was bent from someone cranking on it. It took a lot of finagling to fix that. Now it works through its whole range. These adjustments are crucial to proper use but are not like anything on any other machine tool I'm aware of. It takes some familiarity with this brand of shaper to know how these work.
Besides the vise the other most scavenged part off old Atlas7b's are the ratchet box. And you almost never see them on eBay. So be sure this one operates properly in both directions. I don't believe the problem with the ratchet box is the Zemak. I think it's more about adjustment of the link and forgetting to tighten it down. Then it coming loose and causing the box to crash into the X casting. Mine had obviously done that and somebody had done a pretty nice job of welding it. It's probably aluminum brazing or solder as its not JB weld.
The 7b is deceptively simple looking but there is far more moving parts, adjustments and they don't make the parts anymore. I like mine but it's an ongoing process of use and observation then remedy than I hoped for. But for $125 for a complete machine I figured it was worth the gamble. But I'd already put a ceiling of $250 on the whim of a shaper and this one still got me. I've just got a ton of hours of labor in cleaning and fixing with only a $20 motor start cap in parts. And since I need function more than esthetics, I didn't paint it. YMMV and good luck.
tertiaryjim
Mar 3, 2014
616
When buying a shaper, one should determine the machines worth.
For machines of 7" to 12" pay the man twice that amount.
For machines 12" to 16" pay the determined amount.
For machines of 16" and larger pay half that amount.
A little crossover there so it depends on how bad they want to sell and how much you want it.
Downwindtracker2
Sep 5, 2014
411
I think the blue grey Baldor uses for their new grinders is a nice machine colour, so I chose a colour swath at the paint department and had them mix a quart. I now have a purple and Kubota orange shaper.
[6]
[5] [7]
