[4]
How to cut a clean circular hole in cork
[3]
[10] Like what you see?
tjb
Terry
H-M Platinum Supporter ($50)
May 3, 2017
543
I have some 4" round x 1/8" pieces of cork in which I need to mill a hole in the middle. The holes will be somewhere between 1/2" and 1" round and MUST be clean looking machined cuts. Is there a tool to do such a thing, or does anyone have suggestions on how to accomplish it?
Thanks in advance.
Regards,
Terry
Video_man
Nov 9, 2011
143
I've done this with gasket material, using a center-wheel drawing compass fitted with a knife blade instead of a pencil lead. I bought the blade years ago at a hobby supply store, but I expect an amazon or google search might turn one up...or in a pinch, one could grind a drill-bit shank or dowel pin into a sharp blade without much trouble...
RJSakowski
H-M Supporter - Gold Member
Feb 1, 2015
4,123
I have used a drafting compass with a small knife blade (simiar to an Exacto blade) with mixed results It works best with a very sharp blade and multiple light cuts. Another way would be to make a gasket cutter from some suitible tubing. Sharpen the edge well and twist as you make the cut. A lot depends on the nature of the cork. A Forstner blit with the cork sandwiched between two pieces of thin plywood should also work.
Latinrascalrg1
Brass
Dec 9, 2016
599
However you proceed to cut the cork in the past ive gotten the best results by first hydrating the cork. Steam works the best but if its not possible to steam then covering with a wet cloth or spraying with water until its absorbed enough moisture to Not Crumble.
Once softened, use a 1" copper pipe to "punch" cut the hole by sharpening one side of the opening edge all the way around. I like to have the beveled edge on the I.D. of the pipe which will give you a almost perfect sized hole the shape of the pipe opening.
benmychree
John York
Jun 7, 2013
3,545
I have cut lots of cork with an adjustable pivoting gasket cutter, they use a center pin to pivot on that fits in a hole in a backing board and use a razor type of blade held at about 45 deg to the cork. Dampening the cork is a good plan, especially if cutting thin walled washers.
tmenyc
Oct 18, 2018
241
I use cork for vintage piston-fill fountain pens, and have always used a core punch, nice and sharp with a twist to get through. The trick, for me, has always been to have twist get the punch moving and the downward force cut through. Mine are generally in the .200" ID, .250" OD range, so pretty small and thin when done. I've tried a water soak, and it didn't help.
The challenge for me has always been getting the exterior down to the right size and smoothness. Now that I have a bench grinder and a lathe, both will get their chance. I suspect the bench grinder's fine wheel will be best.
Tim
darkzero
Global Moderator
Staff member
Nov 27, 2012
3,800
Just echoing the prev replies....
I needed to cut out double sided adhesive foam rings. I used an Olfa circle cutter.
If you need to cut it to a pretty accurate size, another method is sandwhich the cork in between 2 pieces of alumn (or whatever scrap you have), clamp, then machine the hole to size.
RWanke
Active Member
Aug 23, 2017
141
A cork drill/punch (don't know the official name) is a very easy way to do it. Basically you can make one by sharpening the end of a piece the correct size tubing. The ones we use to use in the lab had a T handle on the unsharpened end for turning.IMG_6897.JPG
tjb
Terry
May 3, 2017
543
Thanks for all the responses so far. I'm finishing up another project this weekend (hopefully) and will begin studying the recommendations. A punch-style thing-a-ma-jig seems to make the most sense for a first attempt, and I'm thinking of trying to operate it on the lathe a la jcp's post.
Keep the comments coming, and I'll post results (with perhaps more questions) as I proceed.
Regards,
Terry
tjb
Terry
May 3, 2017
543
I thought @jcp meant to use the lathe to make the die....not to cut the cork.
-brino
Re-reading it, you're probably right. I didn't read it quite that way. I interpreted his post as suggesting making a backing plate out of wood or some such product, mounting the cork on the backing plate and then using the tail stock to move the die into the cork - all NOT under power, of course. Several have mentioned twisting the die as it goes into the cork. It struck me that doing it this way, the chuck could be twisted very easily while the die remains stationary. The advantage I thought he may have been referring to is uniform centering among all the pieces. That's necessary because I need to make about a dozen of them.
Thanks for the clarification. I have several pieces of 1" copper about 2" long, and I had already recognized that making the die on the lathe seemed to make sense. Your clarification makes it clearer.
Regards,
Terry
jcp
Nov 29, 2017
154
Regards,
Terry
Sounds like you're on the right track.....keep us informed how it goes.
brino
Jan 2, 2014
3,670
I NEVER meant to say it couldn't be done your way.... try it maybe you invent the revolutionary "tjb" method of gasket production.
In fact, I cannot think of a better way to guarantee ID and OD alignment, unless they were one piece.
Please do let us all know what works for you!
-brino
  • Like
Reactions: tjb
tjb
Terry
May 3, 2017
543
Yeah, I caught that. Actually, jcp's post combined with your clarification provide what seems to me to be a good strategy:
1. Make the die on the lathe which undoubtedly will produce a cleaner edge than I could accomplish with my less-than-expert ability with a file. (This step would never have hit my radar screen without your clarification. Thanks.)
2. Fabricate some form of holder for the die to mount it in the tail stock.
3. Mount the cork blank in the 3-jaw chuck (I have a mental picture of how to make the backing plate for it, but I suspect I'll modify it somewhat as I'm building it.)
4. With lathe in neutral and not under power, feed the die into the cork, twisting as necessary with the chuck.
Still have another project to finish first. To be continued...
Regards,
Terry
yendor
Dec 11, 2013
226
It may sound a little crazy but I have used Brass Tubing from a hobby shop for this sort of job.
Cut it to about a 3-4" lenght.
Use a RatTail File to sharpen the edge on one end.
Insert a press fit dowel rod in the other end for the 1" you will need to adapt/turn down the dowel but then chuck it up in a drill press and it makes a nice clean hole.
The only down side is you will need to re-sharpen the cutting end frequently as brass tubing won't hold an edge long.
I've done this many times when I've had a Paper Manuals that weren't 3 - hole punched for a binder.
[5] [7]
