I would like to cut some fiberglass hard panel, 1/4". Is there an easy way to do that safely? The piece I have is a bit big, so I can't put in water and cut it. I would if I can. The only tool I think would work is a table saw or a circular saw, but other ideas would help. So I don't know how to keep it wet to keep the dust down to minimal or 0.
I just need to cut a large box (30" each side), into panels so I can store them. Once in a while, I need a piece, like when I needed a piece for doing 3 phase converter.
What do you think?
If not, I will just post and give it away, all else, it will go to trash.
What do you think?
