Okay i have a question!
I made the small assembly tonight, just the small recessed bit.
I learnt how to use my boring head, so that was good and the fit is pretty good too!!
And i also used a hand file to get the radius parts so that when they are placed on each other the edges line up.
I have not used a file in many years.....
Polished it up starting with 600 WP and oil going through to 1000 WP and then 2000WP and finally onto the buffing station and some Acrylic polishing compound that
works a treat on metal! One of the advantages of being in the dental field!!!
The test tube slides inside the small mount and i need to drill 4 holes, one in each corner all the way through the larger base part.
I have never tapped a blind hole and would rather not snap a tap and have to remake the base.
So i will go the easy route this time!
How would i go about drilling the holes so that everything lines up nicely??
I was thinking of using some double sided tape and mounting it in the mill and then drill the holes all together.
If i do them as two separate parts i am sure the holes will not line up!
Is there another better way of doing this???
Any help appreciated!!!
Andrew
Andrew
