- Jan 2, 2014
- 8,851
A couple years ago I bought a Cub Cadet LTX-1142KW ("KW" designates the Kawasaki engine).
I really only have two complaints about the machine:
1) the grass height settings only cover the range of short, too short, way to frigging short and scalping.
It might be fine for someone that can cut all their grass every other day in May; but I'm not that guy.
It takes over four hours to cut all the grass, and I can never seem to get it done in one session (run out of gas or daylight, driven in by rain or bugs, etc.)
So by the time I finish cutting the entire yard it's time to start at the other end again.
Then the grass is so long that I'm leaving windrows
I have looked a few times at the linkages wanting to hang the mower deck higher, but that doesn't look easy.
I have started to wonder about just putting bigger tires on to lift the entire machine.
But that problem is for another day.
2) The local mice population love the top of the engine for building nests. I have just removed the second nest of the year. Disgusting!
So far they have not chewed thru any wires, but I want them gone.
Previously I had cleaned it up with peroxide and a brush to get rid of the smell.
I did not get a picture of the top of the engine once I removed the nest, but it is basically the fan on top of the flywheel.
I found a picture of a similar one below.
I will continue the battle to mouse-proof the storage shed, get some different traps in there, etc. but I am also looking for ideas on something I can put on the engine to dissuade them building there in the first place.
I need something that:
-brino
(a similar picture from the web)
- mice find sufficiently nasty
- won't be slung off within the first two minutes of running the engine
- won't start a fire when the engine gets hot
- won't just dry up and disappear when the engine gets hot
- won't damage the engine
-brino
