- Feb 7, 2013
- 2,481
Needing a circuit diagram for the Caterpillar D6C, I looked on the web and found what I needed,
however, I was not able to print the diagram as it was a PNG file. I did a search for "convert PNG
to JPG" and found several entries that would do just that. It was really quite easy to do.
So, now I can check out the wiring as the ammeter does not work on this machine and I
think the wiring has been modified by someone else over the years. It could easily be
a corrosion thing as well because the wire nuts and bolts have been out in the elements for years.
Being unable to print PNG files has been a problem many times in the past so hopefully this post will enable someone else
who has experienced the same situation.
