- Sep 22, 2010
- 7,223
I have read that the procedure below is used to set up and adjust a steady rest for use in holding bar stock on a lathe. Is this correct, or is there a better way?
Thanks,
Nelson
To adjust a steady rest for any size bar stock, use a combination square blade with a center head to scribe two intersecting lines on the end of the piece of round stock
Chuck one end in a 3 or 4 jaw chuck, and place the steady rest near the tailstock end of the round stock, clamping the steady rest to the bed ways. Then put a center drill in a drill chuck in the tailstock. Adjust the steady rest jaws to center the point of the center drill to the intersection of the scribed lines. This will approximate the centering of the steady rest.
Close and clamp the top of the steady rest and make sure the jaws are in contact with the bar stock to remove all wobble. Use some grease to prevent the jaws from scoring the workpiece. Note: Any work mounted in a lathe for machining is called a workpiece.
Start the lathe spindle, and drill the center hole in the end of the workpiece, the center drill will automatically find the exact center of the workpiece.
You can now loosen the jaws of the steady rest, and put a live or dead center in your tailstock spindle. Tighten the center into the centerhole in the workpiece. You can now reset the steady rest jaws on the workpiece. This centers the steady rest exactly; and if you follow these steps, the workpiece will not crawl out of the chuck.
Thanks,
Nelson
