  • PLEASE SUPPORT OUR FORUM - UPGRADE YOUR ACCOUNT HERE!
[4]
How To Use A Multimeter To Test
[3]
[10] Like what you see?
British Steel
Active Member
May 12, 2011
761
Likes
635
#61
You can get sticky labels with "not in calibration system - for indication only" to slap on cheap meters...
Dave H. (the other one)
Dredb
Active Member
Active Member
Jan 6, 2018
89
Likes
84
#62
You might try it without a voltage regulator. I have an old Simpson 260 that had the 15 volt battery that probably is no longer available.
I put two nine volt batteries in series( 18volts) and it worked out just fine. The variable rheostat that sets the peak needle reading compensated
for the increased voltage of the two nine volt batteries.
EDIT: Oops! I see you already tried that. I usually set my needle before use anyway.
If you want to reduce battery voltage put one or more forward conducting silicon diodes in series with one of the battery leads, each diode will drop about 0.7 Volts. Select diodes for suitable current rating.
[6]
[5] [7]
