how would you finish this bore?
magu
Jun 6, 2014
183
I apologize in advance for being vague; I am building a small machine tool which I would really love to do a build journal for as I think others would find it fascinating, but in doing so I would inadvertently be spreading someone else's design around the internet. For anyone who is also into sheetmetal forming, I am building a mechammer from Ben's (bensmetalshaping) plans.
On to the question though: I am turning a piece of 304 ss which will be a cylinder for a sliding piston and needs a very good finish bore for the piston rings to seal against. The bore will be ~1", it is not critical that is 1.000, 1.001, or 0.999 as everything will be a one of matched set and the piston and other parts will be machined to match the bore. Once I have roughed out the bore, what would you recommend for finishing it? Options I have thought of are:
- a spiral fluted chucking reamer: this would probably do the job well, but they are not cheap, and I don't know if I would have any issues reaming a 1" hole from a power/machine standpoint
- an adjustable reamer: I am not concerned about being at an exact diameter, so the adjustability doesn't bother me, but I have never used one. This would be significantly cheaper though, and could be used for a somewhat larger range of bores going forward.
- a flexible hone: I don't know if by running one of these up and down the bore if I could improve the surface finish enough, or how consistent the bore would be, I have never used one.
-running a "dremel" type flap wheel up and down the bore while the lathe is spinning, I don't know how well this would work, how consistent the bore would be, or how much I would really improve a turned finish with this method
-feed the final pass of the boring bar extremely slowly and/pr multiple times and leave it as is
Anyone have thoughts or other ideas?
Thank you both.
Bill, If I were to lap it, how would you go about it? The bore is ~5" long, I have lapped pistol slides and valves before as well as rotating components, but I have never lapped an extended bore, and have always had the male and female to lap into each other.
4SSSS, would you recommend a flex hone, or one with fixed blades? I haven't ever honed anything other than brake calipers and engine cylinders before.
If you've honed brake calipers, it's the same process, unless you can get your hands on a Sunnen. If lapping, a speed lathe (or a fast lathe speed) with a wooden dowel cut to a pencil point and just going back and forth will do it, but being 5" long, you probably wouldn't get it straight.
Iron oxide is softer than iron, but Cr2O3 (a chromium oxide) is 8.5 on the Mohs scale, while steel is
around 4.5, so rubbing at bits of stainless will be a lubrication problem. The iron and nickel oxides
will turn the oil (black? green?) but the chromium in the stainless turns into abrasive.
I think that means that the rings will lap that cylinder for you, in short time.
If its for a piston with "rubber" seals its doesn't need to be "perfect" diameter from end to end either. It just needs to be smooth. A brake hone should work fine. Once you have it very close if you use the hone with good technique I doubt you would wind up with more than a thousandth variance anyway. You might get a very slight belling a the ends as the stones come out or go in, but I doubt it would be huge or a huge issue.
I do have an micrometer adjustable fixed hone I used on a quill bore on a CNC Mill, but something like that would be WAY overkill for your application I think.
You mentioned 304SS. Have you started machining it? It is a bear to machine. It work hardens just looking at it. If you already completed the machining, then as others have mentioned some combination of Grinding and Lapping should get the surface to where you want it, as my experience with taking light cuts on 304SS has never been good.
If you haven't started machining and other materials are an option, you might consider something like 303SS as it machines much better.
Yes, 303 is a much better choice than 304; I made products in my shop before retirement and used 303 for everything we made for the wine industry, the only drawback is that it does not weld as nice as 304, it tends to undercut at the edge of the weld edge when using TIG.
The only other thing I'd question is the use of any 300 series of stainless, they tend to gall up with sliding fits especially against other stainless parts.
What are the rings made of? What is being sealed? Iron rings need some ruggosity to allow them to bed in and to retain some lubrication,(honing). O-rings in a hydraulic cylinder need an almost polished surface,(lapping and polishing). Wet & Dry emery paper around a wooden dowl with a slot in it will clean it up as fine as you want, Kerosene for lube/wash. Whatever you end up doing scrub with hot soapy water and rinse when finished.
