[4]
Huh...
  • Thread starter Deleted member 43972
  • Start date
[3]
[10] Like what you see?
D
Guest - Please Register!
guhhh... That really sucks. That was a good tap too... huhhhhhhhhhhhhh
Z2V
H-M Platinum Supporter ($50)
May 10, 2017
742
How were you holding the tap? Were you tapping under power or by hand? Sucks to break a tap, especially a good one. :oops2:
D
Power tapping holding the wrench. I got greedy. I felt it tighten up and let go and I stopped, but instead of backing out, I turned again, *clink*... effff.
5/16 - 18 dormer spiral flute
Z2V
May 10, 2017
742
Well, hopefully you don’t have too much trouble getting the broken tap out of your work. There’s something to be said for backing out a little when it starts getting tight!!!
Z2V
May 10, 2017
742
Wow, how did that happen? I promise, I’m not shouting, LOL
D
Haha.
Nah, it’s a long piece of bar stock. I’ll just cut it off and do it again.
This is my first major swing at stainless... took me over an hour to get that step right and get as far as to break the tap... try again tomorrow, but, with a regular tap, cause that’s all I have left. Baby steps... baby steps...
  • Like
Reactions: Z2V
magicniner
H-M Supporter - Silver Member
Oct 21, 2017
475
What grade of Stainless?
What Cutting Lube?
What % thread were you going for?
The Devil is often in those few details ;-)
Norseman C.B.
Active Member
Dec 21, 2013
280
Stainless is one tough butch sometimes, and K Monel is even worse..........:headache:
mmcmdl
H-M Supporter - Gold Member
Staff member
Jan 31, 2016
1,437
At least the back half of the tap is still good ! You can now make a pointer or small boring bar out of it ! ( look at the positives ) ;)
D
Tap broke off right at the last thread. The other half is just a straight shank.
I don't remember the grade... It was blue and red.... Lol
The lube was the green goopy stuff.
I drilled the hole 17/32" so, slightly oversized for a 5/16-18.
benmychree
John York
Jun 7, 2013
3,136
Next time try TapMagic instead of the green goopy stuff, and 303 stainless is a free machining grade that takes a lot of frustration away from working stainless; I used it extensively in my product line of winemaking tools in place of 304 with never a problem.
D
It was 304. I emailed metals plus to ask what red and blue was since I couldn’t remember.
I grabbed it in place of drill rod for an indicator stand. They didn’t have drill rod on the shelves and I didn’t feel like paying for a cut.
I got it all finished tho. Also had to make a slitting saw arbor. Not pleased with the turn out of that. Has some run out I’d like to eliminate. So, when I have some more time I’ll take a bit more off the shoulder and do the final pass in the mill.
D
Indeed. 17/64". Not quite the hotdog down a hallway of 17/32...
westerner
If you are gonna be stupid, ya gotta be TOUGH!
Mar 29, 2017
229
"Not quite the hotdog down a hallway" LOL. I know I have heard that before, but it is still VERY descriptive! Much similarity to my last attempt at creating a precision hole using an adjustable reamer!
D
I’ve had ONE experience with adjustable reamers. Bought a set from busy bee tools, adjusted it to the size (no easy feat...) promptly broke it off in the hole, immediately brought them back, never looked back.... juuuuuuunk.
Maybe a quality kit would have been good, but I’ll stick with normal reamers,
[6]
[5] [7]
