Ulma Doctor
Infinitely Curious
Feb 2, 2013
3,609
I got a call from a customer saying that his hydraulic sausage stuffer is not functioning correctly.
i took a look and found that the control valve actuator fulcrum had failed due to excessive wear in the captivating pin and the fulcrum.
the fulcrum is a stamped piece of 16 gauge galvanized sheetmetal with a couple holes in the right places.
the customer wanted it quickly so i decided to make the part rather than wait for one to be shipped out
i cut some 7/8" Square 12L14 on my power hacksaw and laid out the holes and channels to be milled
after the milling operations,
i flipped the part and drilled the 3/16" holes for my shop made retention pins
BEFORE / AFTER
Here is a shot during fit up
here is a shot of the completed fulcrum.
the only thing left is to install 10-24 nylock nuts to the 3/16 fulcrum pins
i replaced the spool valve pin with a new 3/16"x1" spring pin due to wear.
with any luck, the new actuator fulcrum will outlast the OEM.
it is definitely heavier in construction :big grin:
Thanks Silverbullet!
i try to make replacement parts better than the manufacturer whenever possible. :)
BEFORE / AFTER
Yeah, that'll never wear through. Haha! Nice work!
Sent from my Moto G (4) using Tapatalk
I love chorizo!
Shouldn't the original part be stainless? Food industry and all?
R
I love chorizo!
R
Hi RWM,
luckily the control valve (and all the hydraulic and electrical apparatus) are in an enclosure.
there is no direct interface between product and controls, the hydraulic actuator shaft has a bellows type seal.
i guess that's how they were able to get away with the galvanized stamping.
i like the idea of the SS actuator, i may just produce one for fun- now that there is no emergency! :grin:
That would be one heck of a way to keep your customer....show up with a replacement SS actuator at no charge!
Robert
