I have a space problem, lathe related, New ACRA 1440 TVS
Terry IIrc others have replaced the 2hp with a better 2hp Vector motor, and fitment was an issue. One issue I have is with the Norton open style gear box, it needs a one shot oiler, that I have done. I am constantly questioning if I am oiling the gears, and bearings enough, there is the oil cleanup because the oil drips out of the gears, and onto the chip tray.
Bummer. Just a thought.
I appreciate all input:encourage:
  • Like
Reactions: tjb
Have you considered any oils with "tackifiers"? AFAIK, they're a lot less likely to drip than regular oils.
I'm using the DTE 26, I also have Vactra #2, and plain ISO 68.
So several points that I have mentioned to Mike and some additional concerns.
Based on the DOC he is using (0.3") with a 3/8" CCGT insert, as well as the size of the hole he is boring (1 9/16") he is actually pushing his current lathe and tooling beyond its physical limits. If you are stalling out the motor on the VFD, then you are exceeding the limitations of the machine in my opinion and something is going to break. An inverter/vector motor could help a bit but just means something else is eventually is going to fail. The main idea is to use a machine within it operating envelope.
The forward option is either to change how he is turning down stock, less DOC and increase the feed, as well as consideration of deep boring with a large carbide boring bar. I use a 1" and have bored up to 8" deep in steel, but the rate of removal is nowhere near hogging it out with a large MT drill.
So one reason why I felt that if one needs to upgrade for more aggressive turning, you would be better off with a larger heavier lathe, with a bigger spindle bore and a beefier tailstock that can take MT4 drills. This is based on direct experience with the 1340GT/ERL-1340/1440C and the larger RML/TL/TVS size lathes. Unfortunately there is a lot more cost to just upgrading the lathe as the latter machined benefit from CXA tool post holders which can achieve a 0.3" DOC.
Space wise it may be best to do a cardboard template/layout lines on the floor and work with whomever you are sharing the space with. If you need to get rid to the RPC, you can get an inexpensive $200) 1Hp Teco L510 VFD 120V with a voltage doubler and output 3 phase 240VAC. It is a no brainer install, connect the motor to the VFD terminals, connect the power in to a 120VAC plug, use either a single open/close switch for the run or two momentary switches (NC and NO) with 3 wire control in forward only direction. I will walk you through it if you need it. You have not worn me out yet, but getting there.
As far as the open Norton gearbox, they are messy. Many people weld up a trey to catch the oil that drips down or get some small disposable aluminum treys and mold it under the gearbox. If it is dripping oil down fromthe gearbox then you are most likely oiling it enough, my main issue with the stock single oiling port is you need way more oil pumped in to get to the other side. Other option is a pump oiler with a distribution system. This has been extensively posted on.
:coffee break:Following along Mike . I brought home 3 breaker boxes last night so I'm seeing some progress on my end . You wanna talk about space issues ? :eek: I'm trying to lay out the basement and the garage and see what fits where . Not sure at this point IF everything will fit . It's another WIP .
Thank you for responding Mark. I'm going to look at a new layout on the,floor, it's hard to imagine now since I've only done it one way. The RPC can actually be moved to another power source closer to the saw, and be secured. I just have to reimagine the floor plan, and measure it out.
I have been doing some research, PM has 2 1440TL lathes in transit 1 month out. I like the 2.5 spindle bore, but no VFD, it has 12 speeds, and I would have to forgo the VFD for now, I would also need to upgrade my 5hp to a 10hp RPC motor. ACRA will have the 1440 TVS in stock next week. What is a fellow supposed to do? Help....
The VFD is available user installed:eek 2::faint:
