[4]
I was taught a new way to use an edgefinder today. What are your thoughts?
[3]
[10] Like what you see?
9t8z28
Active Member
Aug 16, 2016
243
Today was my first day on a new job. The guy training me asked me to find the edge of the part so I pop in the edgefinder and crank up the spindle to 1K rpm. I then flicked it with my finger to get it running off center, move it into the part until it runs true and then just when it kicks out I know I am on the edge of the part plus half the diameter of the tip. In this case its a .2” diameter tip so I have to advance .1”. This is the way I’ve done it a million times and I’ve even checked the accuracy of my edgefinders with my DRO and a DTI. Anyway, The guy training me tells me I am doing it wrong and tells me to get out of the way so he can show me how its done. His way of doing it is exactly like I described above but after the tip kicks out on the side of the part he reverses the table until the edgefinder runs true.
I was at a complete loss of words. Being my first day on the job, I didn’t want to **** the guy training me off.
I did ask him what kind of edgefinder it was and he said it was a normal edgefinder. I had a good look at it and it is identical to my Mitutoyo 050101 and starrett 827A which are both a 3/8” body with a .2” tip.
What are your thoughts ? Is there some kind of a new edgefinder that I’m on unaware of ?
benmychree
John York
Jun 7, 2013
2,867
Your way is about the way that I have always done it, but I, advance very slowly until there is no "air gap" to be seen, with back lighting, so I guess that I am somewhere in between the two of you, it is possible to go a little past the zero point doing it the exact way you describe; someone years ago also suggested that grinding a small flat on the .200 dia. makes it all the more sensitive --- it works!
T Bredehoft
Dec 27, 2014
2,833
I advance the part until it stops wobbling then back it up until it just starts. I find (for me) it is easier to see the beginning of the wobble as apposed to see the end of it.
9t8z28
Active Member
Aug 16, 2016
243
Have you ever tested this message to see how accurate it is ?
dulltool17
May 9, 2014
343
..which is as I was taught, many years ago...
Technical Ted
Nov 5, 2016
738
I was taught the same way as you and I've always done it that way and I've never really given it much thought; until reading your post...
I'm thinking that the person training you feels that for an edge finder to run off you must actually be a little past the edge. If not, in theory anyways, seems like the edge finder would be running true when just first touching and would have to be past the edge for the finder to move out and run down the edge of the work piece. He probably has a point.
But, for my use anyways, I use an edge finder to get me close i.e. within a thousandths or two of an edge and if I have a critical dimension I want to hold I would check it by some other means than just trusting and edge finder and then dialing off the distance (especially without a DRO).
So, old habits die hard so I imagine I'll continue to do it the same way.
Interesting topic!
Ted
MrWhoopee
H-M Supporter - Silver Member
Jan 20, 2018
553
Run the edge finder up until it just kicks sideways, set the dial on the mill to 100. Taught that way in school, confirmed by my first boss. I've never seen it done any other way.
Edit: I do back off after setting the dial and slowly crank up again to double check the setting.
P. Waller
H-M Platinum Supporter ($50)
Mar 10, 2018
910
Welcome to the world of working in machine shops, many people have different methods of doing the same thing, you will find this to be true in short order I suspect.
Do it this persons way until they stop watching you at all times then use the method that you are accustomed to, as long as the parts are accepted over and over no one will care.
I do exactly what your trainer does by habit, not because it is better but for the simple reason that I have been doing it that way for 30 years of working full time in machine shops.
The only right way to do something is the way that works.
MrWhoopee
Jan 20, 2018
553
Just found this video by Tormach. It says that the difference between the edge finder running true and kicked offset is .0005. If that makes a difference, you shouldn't be using a mill or an edge finder.
4ssss
Brass
Apr 25, 2017
546
X2
Holescreek
Nov 10, 2013
771
He's wrong. How does he know when the table is no longer touching the edge finder? It will continue to run true after it is no longer touching the part.
RJSakowski
Feb 1, 2015
3,755
The edge finder has been my weapon of choice in finding an edge for more than thirty years. I usually make three approaches, the first rather quickly to get a rough idea of where the edge is and then advancing about .0001" every 1/2 second in the last 1 to 2 thousandths, repeating the procedure until I can locate an edge to .0001".
Approaching too rapidly will give a false position, either due to overshoot or if there is a small amount of wobble, kicking out prematurely. It has been my experience that once the edge finder kicks out, you have to back away by several thousandths before the edge finder settles back to a stable mode.
I routinely use my finger nail to recenter the edge finder after backing out about a thousandth as this reduces the amount of travel for the next approach. If I don't use my fingernail to recenter the edge finder, I have to back it out about 6 thousandths before it resets, at which point, there is a clear air gap between the edge finder and the work.
RJSakowski
Feb 1, 2015
3,755
He is saying that the difference between the centered edge finder and being kicked out is .0005", not going from offset to centered again.
The edge finder of this type was patented by Robert Beatty in 1948. (US Pat. 2451904) Among his claims was that when an edge is contacted by the centered finder, the additional travel to the point where the tip is displaced is never more than .0002". Starrett also makes this claim for their product.
Holescreek
Nov 10, 2013
771
Like everyone else, my Bridgeports were bought late in their lives and came with some "slop" in the screws. I have a DRO with glass scales to take the guess work out of everything I do. I use Fisher edge finders (not the ones that click) just about every time I set up a new part, be it picking up an edge on finding the mid point between the jaws of a part in the vise. I set the DRO when the edge finder kicks out, then I back off and do it again. 99.90% of the time it kicks out within .0002" of zero. I do the same thing when finding the mid point, I touch each jaw and look at the number on the DRO. They match the same percentage of the time. If I need real precision I'll pick up the edge with an indicator.
I learned long ago to recheck the positions before I cut metal, even if the location isn't that important. When I screw up, I screw up big time.
RJSakowski
Feb 1, 2015
3,755
The great thing about an edge finder is that it is insensitive to runout. The tip centers on the spindle axis. Electronic edge finders, probes and Haimer tasters all have to be zeroed to the spindle axis to read accurately. As such, the orientation of the device in the spindle has to be strictly observed in order to maintain alignment.
Finding the midpoint with an edgefinder and DRO is particularly satisfying as I find one edge, zero the DRO (don't worry about compensating for the edge finder diameter) and find the opposite edge. Then I hit [1/2] on my Grizzly DRO or enter "/2" and [ENTER] on my Tormach PathPilot display. Zero is set at the center of my part. Sweet!
Holescreek
Nov 10, 2013
771
Here's why he's very wrong:
Lets ignore DRO's altogether. I never saw one on a Bridgeport until about 16 years ago. A skilled operator will snug the table lock slightly when approaching zero to remove table slop and keep from overshooting a number. They will also approach a dimension by turning the handle in one direction only to keep the lead screw on one side of the nut. If they overshoot the number they'll back off a full revolution and re-approach to remove all backlash. Having the lock snugged also allows some tension between the interacting surfaces.
Backlash on a Bridgeport (dead space between the lead screw and the Bronze nut) is typically set around .025". If you change directions after your edgefinder kicks out, far enough to draw it back concentric you've not only removed all tension you set finding the edge, you're now on the wrong side of the nut (if you're lucky) and will need to use that same direction on you handle when moving to the next position. More than likely you're actually lost somewhere in the backlash.
So nothing ever changes. The dude is doing the Alpha Dog routine. Watch for wet spots in the corners of the shop. I chuckled about this on the long drive home tonight.
vtcnc
Administrator
Staff member
Jun 29, 2014
394
Morning everyone! Please keep the conversation focused on the merits of the ideas and make sure we don’t drift into what could be misinterpreted as personal or ad hominem attacks on such a trivial life matter.
I think somebody said that at the end of the day, if the part is good, then there you go what’s the big deal?
I’d like to hear from members which method is faster, more repeatable, etc., without hearing that the other side is wrong - because they may be achieving the same accuracy but with more aggravation, more effort, more rpm, more hand wheel work , more math , etc.
Cadillac
Brass
Mar 12, 2018
645
Holescreek nailed it. Backlash would be your enemy attempting to return. I have a dro and really don’t worry about backlash except for these exact reasons.
Dabbler
Administrator Trainee
Staff member
Oct 11, 2016
728
How I was taught by a tool and die maker, is what is 9t8z28 tried first, except that he taught me to zero the DRO after the first attempt, and then repeat, always 2 tries. If they don't agree, you have to repeat until you get the same measurement. He demonstrated to me getting to withing one tenth reliably, many times in a row, with a very sloppy lead screw (just before he rebuilt the nut).
with my offshore edge detectors, I am getting within 2 tenths every time, wo it is what I do...
gmcken
Sep 2, 2013
67
I find the edge just as Dabbler suggests. Zeroing the dro after the first touch off with edge finder and checking until I get repeatable readings. Good discussion by members
dlane
Sep 27, 2014
3,045
Cigarette rolling paper works for me, I have an edge finders but the papers are quicker. :cool:
RobertHaas
Active Member
Mar 16, 2016
81
Pre DRO I learned the move in slow to the kick. set the dial to half the Dia. of the edge finder then repeat to check work. It's funny but I make a habbit of doing things analog (or mechanical) then check my work with the DRO and feel so proud of myself when I hit it within a thou. or 2
Bob Korves
Jul 2, 2014
6,184
I don't like to leave the cylinder rubbing on the work for long, figuring that will cause wear in and on the edge finder. I go in once fairly quickly, then once slower, backing out immediately after seeing the number. On something more fussy I go more slowly, and had most of RJ's excellent and eloquent post figured out, but use it rarely when I am trying really hard to get it right.
RJSakowski
Feb 1, 2015
3,755
I would suggest that anyone concerned about of their edge finding method run an R &R test.
Repeatability: make multiple approaches to the edge and note the position with a tenths reading DRO, dial indicator, or test indicator.
Accuracy: find the opposite edges of a reference block, noting the difference in position with a tenths reading DRO. Measure the reference block with a known good micrometer and compare. This test would be more difficult without a DRO as position would depend on the accuracy of the lead screw, the ability to accurately read the dial to a tenth of a thousandth, and would have to take backlash in the lead screw into account.
I ran an R & R study this morning using my mill. I mounted a 1-2-3 block on the table and swept the 3" face to verify that is was parallel to the y axis within .0005" I zeroed the DRO in both y and z to ensure that I could return to those settings. I then ran the edge finder to the left side of the block and zeroed the x axis. I was able to return to the exact same reading on multiple approaches. Readability to .0002" (the resolution of the DRO) confirmed.
Next, I lifted the edge finder to clear the block and approached the opposite side. I approached multiple times, again verifying repeatability. My reading was 2.4998". Subtracting the .5" edge finder tip diameter., the distance across the block was 1.9998". Finally, I measured the the 1-2-3 block at the contact point at 2.0000" with two different micrometers. This amounted to a difference of .0002" or .0001" per side. The Accuracy confirmed.
In my experience, several considerations are in order when using an edge finder. The edge finder contact surface and the surface of the edge being found should be clean and smooth. An oil or coolant coating will will create a film which will create drag on the edge finder tip and cause a premature jump. I use a contact length of about 1/8" rather than exposing the entire tip surface. When center finding using opposite edges, I make sure to use the same contact length. I use around 700 - 800 rpm for spindle speed. I also use a very light coat of oil between the tip and the shank of the edge finder. I apply a droplet of oil to one surface and wipe it off, removing most of the oil. I find the this gives more consistent jumps. Erratic movement of the tip is a good indicator of the need for lubrication. I set the preload on the spring at about 2 lbs. n My edge finder of choice (I have two full sets of them) is a 1/2" one that I bought from Enco or Travers maybe thirty five years ago. I prefer the 1/2" to the .200"; I think that it gives a crisper jump. The larger radius means that less drag force will be required to make the jump.
RJSakowski
Feb 1, 2015
3,755
The one fault that I have with the edge finder is the mark that it makes on softer materials. There is the possibility of creating a slight indentation on materials like plastic and I will also try to back off as quickly as I can. As far as wear of the tip goes, I can't measure any after 35 years of use.
[6]
[5] [7]
