- Jul 28, 2017
- 2,369
For awhile now I've been dealing with a noise problem affecting some of my remote reading Igaging DROs (attached to a mini mill). The mill's motor is a variable-speed version, controlled by PWM. The PWM noise sometimes gets into the DROs, causing them to lose their position. I put braided shielding around the cables going between the sensor and display units, which helped a bit (but did not completely solve the problem). I soldered a 1 microfarad capacitor between the sensor's Vcc and Ground, and that helped -- a bit more, but it didn't eliminate the problem, either. I made sure I had single-point grounds to avoid ground loops. Didn't improve things. Replaced the conductive rule mounting hardware with insulating ones. No improvement. Due to the fact that shielding didn't help much got me thinking that I was dealing with magnetic interference, not electric fields. Copper braid won't address magnetic field interference. And the effective source impedance of mag-field interference is very low, which would explain why a 1uf capacitor was not completely successful at fixing the problem.
So in a desperate move I did some surgery on the most problematic axis' DRO sensor (Z, the sensor closest to the motor). I got to the circuit board and severed the Vcc line coming from the USB connector, then soldered in a 1.5K resistor to restore the connection to Vcc. The idea was to filter Vcc. And this, so far, appears to have solved my problem.
My approach is not for those who are not experts at soldering. I had to use a fine tip soldering iron under a stereomicroscope to avoid solder bridges across the USB socket terminals. But later I figured out a less-demanding way to do the same thing, with no circuit board surgery. The cable that goes between the display and sensor can be modified. There's enough cable inside the sensor box to do it there -- cut the cable, insert a 1.5K resistor in series with the Vcc line and restore the other connections. The 1uF capacitor still must be added between Vcc and ground. And use heat-shrink tubing to insulate the connections. Yuiry's Toys indicates you can't depend on the wire colors being the same from batch to batch so I'm not going to indicate what wire color the Vcc line is for mine.
The sensor's low current draw doesn't produce much of a voltage drop across the 1.5K resistor so normal circuit operation is not affected. Power dissipation is not an issue so you can use a small resistor -- 1/10'th watt, if you've got 'em.
Some may ask why I'm going through this rather than buying "real" DROs that use magnetic or optical rules. 1. Budget (I already have these). 2. Fixed Income (retired). 3. Hobbyist (I've got the time).
