- Jan 21, 2013
- 862
I have my HF 8" grinder working acceptably now, and Have the first white stone I've ever used mounted on it. What a difference it makes! Sharpening/shaping lathe bits is a pleasure now. I decided to try out sharpening a cheesy hardware store 7/8 drill bit. I decided to try using a 140 degree included angle instead of the typical 118 according to an article I found. I only used a protractor for the 70 degree sides, and eyeballed the rest.
I have some gummy hardware store steel that I keep around for testing/playing around so I don't waste the good stuff. Drills of this size typically spin the taper loose from the tail stock without a tommy bar, but this time I didn't need it even cutting dry. Granted, it's sharper than it's ever been before, but I have to think that the reduced force required for that shorter nose profile is helping too. Now I have to do all of the silver & deming pits in my HF kit. They drill, but the edges are pretty dull.
Doing this by hand goes against all of my OCD needless-precision instincts. I want jigs and such to ensure perfect results and repeatability, but dang, this ain't bad at all.
