Bunch of amateurs set up and programming on display there. Any decent operator should have caught most of those, especially on the lathe. Mills are a little less obvious when something is GOING to go wrong.
Ouch, never liked running those machines. Someone else would program and edit while I ran production. The programer always ran the machine without cutter just to check the tool path. First CNC lathe I saw had a homemade safety grid on the sliding door at had a cracked window.
