[4]
In a hurry
[3]
[10] Like what you see?
Scruffy
H-M Platinum Supporter ($50)
Jun 5, 2013
512
Was in a hurry today because it was starting to rain and I had to get 4 white oak logs loaded on the trailer. 2 of them needed the but’s well cut off.
The moral of the story is don’tfill The gas tank of a 395 xp husqurva chain saw with bar oil.
Thanks scruffy in ohio
jcp
H-M Supporter - Gold Member
Nov 29, 2017
154
Yeah...me to.
Downunder Bob
Staff member
May 16, 2016
1,133
I've heard of adding a bit of upper cylinder lube to the fuel, but there is a limit. besides it's two stroke anyway, bet it ran smokey for a while.
FOMOGO
Sep 2, 2013
2,008
Kind of like adding several gallons of gas to a 40gal diesel tank. Always best to wait until after morning coffee to do this stuff. Mike
Downunder Bob
Staff member
May 16, 2016
1,133
I won't bet on it, sure as hell if I do, I'll end up doing it. I think my windshield washer fluid is more than methanol and water, cos it makes lots of bubbles, I think there is some heavy duty detergent in there too.
Many years ago a good friend put Diesel in her motor bike, she has forever since been known as Diesel Di, she wears the name with pride.
Al 1
Active Member
Sep 11, 2011
106
Years ago my son had one of his buddies over to the house. He needed antifreeze in his car. Picked up an antifreeze container from the side of the garage and proceeded to pour into his radiator. Come to find out it was an old container I used to pour drain oil into. I now mark them as drain oil. Al
MrWhoopee
Brass
Jan 20, 2018
745
Years ago, my wife put anti-freeze in the oil filler. :eek:
Recently, a friend filled the fuel tank with bar oil. Local saw shop told him to drain, rinse with fuel, drain again and fill. Then spray fuel (not ether) into the intake. Start the saw and keep spraying fuel into intake as needed until it will run on its own.
GasMan
Newbie
Aug 11, 2014
16
Brake fluid in power steering reservoir, pump growled a bit after.
jwmelvin
Active Member
Jan 11, 2018
161
I’ve done that; drained and replaced before running it and it wasn’t an issue. The bigger issue was the air we sucked into the ABS system trying to bleed while filling the power-steering reservoir. Had to get a shop with the Audi VAG computer to bleed the ABS actuator. It was a buddy’s car. Embarrassing.
Considerably worse, I once lubed my throttle cable with threadlocker. I still laugh about that.
projectnut
Brass
Apr 14, 2014
696
Does that precaution also apply to my Husqvarna 455?
Silverbullet
Gold
May 4, 2015
3,467
Never done it , but made money cleaning many tanks of more then chainsaws. So your not unique . Even sabotaged engines only one I couldn't fix. Pure cola or root beer syrup was poured in the gas and oil. They had got it to start but it froze solid .
westerner
If you are gonna be stupid, ya gotta be TOUGH!
Mar 29, 2017
270
Operator in my fleet filled his HYDRAULIC tank with diesel fuel. And then ran the machine till he ran out of fuel. Job security fo' sho'
philip-of_Oregon
Nov 13, 2017
21
Yeh, the'rs lots of them. they are the ones who never learn.
That is why My Avatar is a Photo of me.
I've learned. ~The Hard Way~.
BTW, the Goggles are actually Prescription Eyeglasses, BEHIND the Safety Glass! They (the goggles) are made in Germany and are Super Comfortable, I had a pair of Glasses where the "arm" just FELL Off, I could not return them, they were made by the VA. So I popped the lenses out, and set an Insert on the lens and marked it with a "Fine" Sharpie.
I then used my Dremel, very carefully following the black line. To hold them in place I simply added "O" rings of the correct diameter.
Neither lens has moved at all, But I did paint the OUTSIDE of the Top, so I can see which direction the Bi-Focals worked!!
philip, from the Great Pacific NorthWET.
bfd
Staff member
Sep 9, 2016
434
did the same thing on my echo saw dumped it out right away and flushed the tank a couple times with gas. then filled and started the saw and ran it for awhile no damage except for ego. bill
Janderso
Jeff Anderson
Mar 26, 2018
1,605
3 times last month. Customer's are putting the DEF (diesel emission fluid) in their fuel tanks. The DEF caps are small blue and the diesel are large green affairs. When this happens and the customer starts the vehicle and drives a bit, this repair turns into an insurance job. The cost to completely replace the fuel system in any late model, Ford, Ram, Chevy or GMC can run over $10,000!!
Be careful folks if you have a newer diesel.
RodJShaw
Newbie
Jan 27, 2015
13
A mountain biking mate of mine in a hurry mistook the dishwasher liquid for Gatorade. We now call him bubbles!
Groundhog
Jan 20, 2016
989
:confused 3: :apple: :eek 2: Yuck. Phooey.
Makes me cringe just thinking about it. (sure glad Mom didn't have liquid soap to wash my mouth out when I was growing up!)
KBeitz
Apr 17, 2018
491
I found out that a chain saw will run on Diesel ...
[5] [7]
