Index 555 Refresh
cmadki4
Oct 18, 2018
6
I'm building a CNC router made from aluminum plate and extrusions. I was able to do all the cutting, drilling, counter boring, etc. with basic wood working tools. But I came to the point where I needed to make a few square pockets and slots. So, I figured "why not buy 2000 lbs of old American iron to make those 4-5 pockets!?" Reasonable, right?
Picked this Index 555 from a guy on Craigslist for $300. Spindles runs quietly and minimal runout. Overall condition dirty, but pretty good.
2018-09-22 17.43.33.jpg2018-09-22 17.43.37.jpg2018-09-22 17.44.02.jpg2018-09-22 17.44.46.jpg2018-10-20 10.42.51.jpg
Came with some collets, a couple end mills and a nice vise. Rented a drop deck trailer and pallet jack and headed off to pick it up. This is a great way to safely and "easily" get the machine home.
Got it home safe and sound and just started to go over it to figure out what needed to be done (if anything).
To get power to the 3 phase motor I decided to go with a rotary phase converter from American Rotary. Static phase converter didn't have quite enough umph to get the motor up to speed in a high gear and motor running on high setting (2500 rpm spindle speed). This 5 HP rotary phase converter works like a champ and is pretty quiet.
With power to it I was able to tinker with it as-is and start to figure what I wanted to do with it. I could make the parts I bought it for originally without making any repairs, but I'm just not one to leave things be.
Main things on the list:
1) replace a gib that was missing (ordered from Wells-Index)
2) scrape the ways, as wear is uneven and movement is more difficult at the extremes of travel
3) remake the lever that engages the quil power feed clutch (it's missing parts)
4) clean and repaint
5) add digital read out
Taking it apart:
2018-10-21 00.35.33.jpg2018-10-21 00.35.37.jpg2018-10-21 00.36.04.jpg2018-10-21 00.36.20.jpg2018-10-24 00.11.38.jpg2018-10-24 00.11.42.jpg
Getting it cleaned up and patching the many holes drilled into the column for whatever reasons:
2018-10-31 00.29.11.jpg2018-10-31 00.29.15.jpg2018-10-31 00.29.19.jpg2018-10-31 00.29.26.jpg2018-10-31 00.29.44.jpg2018-10-31 00.55.21.jpg2018-11-07 17.34.27.jpg2018-11-07 17.34.31.jpg
That's essentially where it is now. Still a lot to do. Scraping will take some time. I've got to borrow some tools from work to get that done. And I'll need to remove the knee, which I believe means I need to remove the head. If I can avoid that I will. I'm not going to high precision here. Mainly just want smooth movement through entire stroke of each axis. I'll update more later as things progress. I wanted to get this out there, because I don't see a lot of Index 555's out on the web being worked on. More commonly see the 55 and 645.
That's all for now...
Great project, thanks for sharing. I'm currently working on a INDEX model 745. I'll be following your progress.
you sound like my kinda guy :grin:
nice score on the mill.
Received my inexpensive 3 axis DRO kit. Quality is pretty decent all things considered. I'll probably make a new more rigid arm for the operator panel, but pretty happy with construction and repeatability of the scales. I think all those decimal places are pretty optimistic though...
Got a little impatient and started to spray a little enamel. Don't judge. It's not a show machine. On the plus side it does show where I need a little extra sanding.
It's got that nice rustic "I couldn't wait to see what this looked like in one color" look. :disturbed:
Some sanding and a few more light coats and I'll be satisfied enough. I'd much rather have this think cutting pretty than looking pretty.
A little progress. Slowly, but surely. I decided to move forward with a few more other items before finishing the painting (since I think i'll need to touch up after the work is completed anyways).
Pushed the machine over into the corner at a 45 degree angle to make more room for the CNC router. I moved the RPC over with it (for which I'll want to build a housing for the idler) and ensured there was room for a small tool cart to store and stage all my machinist wannabe paraphernalia.
Started installing the scales and DRO. X was super easy. Y was slightly more difficult. Z is at a stand still until I get time to figure out the for mounting brackets for the scale. The shape of the column makes it a little tricky.
2018-12-31 18.56.15.jpg2019-01-05 20.30.25.jpg2019-01-05 20.30.07.jpg2019-01-05 18.00.29.jpg
Still a lot to do, but it's fun to pick away at it as time permits. There are a couple of boxes worth of parts not installed on the machine still, but the core components are there, so I can make some aluminum chips once and a while, just for therapeutic reasons. I find taking a large piece of aluminum and turning it into many smaller pieces of aluminum relaxes me... :tranquility:
Progress has been slow and it's actually been awhile since the pictures below were taken. But I wanted to update this with the latest.
I got the scale mounted and dialed in on the knee (Z axis). It was tricky getting the scale mounted with the column being tapered on two planes. So I made a puck out of aluminum using angles measured on the column.
The DRO is awesome and has a few neat functions I've used already. Chamber; for making square/rectangular pockets. Hole Pattern; for making patterns....of holes. ;) It's quite fun to use. It's relatively accurate. Nice to be able to account for backlash consistently.
And I've made a few small "improvements" to the machine.
  • added rubber way covers to protect from chips (and saw dust from other tools)
  • added rubber scraps to table to reduce chip buildup in slots
  • added old bench work light
And that's pretty much it. I haven't done the 2nd coat of paint and not all the non-essential parts are back on the machine (belt cover, various placards, etc.). I had projects stacking up that I wanted to mill and didn't want to waste anymore time on cosmetics. I'll brush another coat on at some point. It's been a good little project. It's nice rounding out my little wood shop with a solid milling machine for those random metal components.
Thanks for looking!
A few items I've machined on it (all for the CNC router):
2019-04-23 21.34.31.jpg2019-04-23 21.35.05.jpg2019-03-11 22.01.35.jpg2019-04-28 12.22.41.jpg
