Hello harrzack,
I concur with kioni5004, if you can run the blade upside down then you will eliminate the tendancy to dig in. You may have to fabricate something as the couple of pictures I attach will show. Please excuse the unfinished appearance this was knocked up fast as all I had to hand was scrap.
The blade is a Widex 25mm, that means the blade is 32mm wide,(the 25mm is the measurment from the base of the blade to the cutting edge of the insert),my lathe takes 16mm tooling so I needed to hold the blade above the top of the toolpost.
Things of particular importance when parting are: Is the blade square to the lathe axis? Regardless of anything else this is critical! Set your toolpost holder by placing a tool holder in place and set it against your chuck. Quick, easy and the first thing to do WHENEVER you fit a parting blade.
Next thing that I'd recommend is when you have determined the place you are about to part LOCK THE SADDLE.
When using Carbide tips, Don't dawdle! They like to get stuck in and if you set up the right conditions they will last and give great servive.
If you do run upside down another advantage is that the swarfh just falls straight down. I've also found that I do not need to flood cool.
Hope this helps.
- Barry
