[4]
Indexable tool holders
[3]
[10] Like what you see?
newbydave
H-M Supporter - Gold Member
Dec 25, 2012
43
What type of metal would one use to make indexable tool holders
Suzuki4evr
Brass
Sep 29, 2017
643
I usually use 4140 or Maybe drillrod and harden it. You need something that is regit enough. 817M40T - EN24T is also a good material to use. Maybe someone else have something els in mind.
Michael
Dabbler
Administrator
Staff member
Oct 11, 2016
939
It depends on what you are doing. On a small lathe taking moderate cuts (say .015 and ,025), you can use cold rolled or virtually any steel you have access to.
If you have a bigger machine and tend to take 'hogging' cuts, then you need to make them with as much cross section as you can and heat treat them to get the minimum flex. 4140 is a good choice.
P. Waller
Brass
Former Member
Mar 10, 2018
921
Is there not a commercially available tool in the configuration you require?
Making an insert tool makes sense if no manufacturer produces what you need, otherwise buy one as it will be far less expensive then making one.
mikey
H-M Platinum Supporter ($50)
Dec 20, 2012
5,464
Just an opinion but the rigidity of a tool holder depends primarily on its size and cross section. The Modulus of Elasticity of steel is such that it doesn't matter if the tool is hardened or not. However, harder materials will resist wear better over the long run.
On the other hand, tool holders for inserts are so cheap nowadays that it might be better to just buy one.
Buffalo21
Feb 24, 2018
179
Let me preface my comments by saying, I love machining and understand people desire to machine and use there equipment, and if iits spending 3 hours to make a $5 item is what make you happy so be it.
I make many things, like parts for a arbor press that were no longer available, or a shaft for an obsolete machine, but what I won’t do is spend 2-3 hours and use up tooling, for something I can buy for less than $20. I have more than enough work to last me the rest of my lifetime, even if nothing else crops up. Will I spend 2-3 hours to make a $100 part, yes I probably would, but to me my time is far to expensive to diddle around with small stuff.
I understand:
Pride in making something
Gaining experience with your tools
Wanting it/needing now
A custom part
When I can buy tool blocks all day long from CDCO (bought hundreds), Shars and others for $11 to $15 each and have them in 2-3 days, why bother trying to make them.
Maybe I’m the only one on the site that feels this way, again I’m not demeaning anyone, if that what you want to do, then do it, I just don’t see the rationale.
Bob Korves
Jul 2, 2014
6,694
I certainly agree with you Jack. But some of us just like to make tools. Sometimes I do, too. And, yes, I do understand that you agree with that, to a point. I am with you on that approach, and on getting some parts made instead..
Rooster
Apr 4, 2017
151
Greetings newbydave, i have used 1018 cold rolled to make 3/8" square indexable holders. One was for holding a ccmt point straight out, the other is for using the other 2 unused corners. Both work just as well as my store bought holders. I have a milling attachment for my lathe so it was fairly easy.
Have some fun learning and making what ever you need or want.
[5] [7]
