[4]
Info on Marvin 4" Dividing Head?
[3]
[10] Like what you see?
JRaut
Newbie
Mar 9, 2018
12
Likes
11
#1
I recently purchased a Montgomery Ward's / Logan 10" lathe. Included in the purchase was this beauty. No name stamped on or cast into it, just the serial number 00042. Some quick googling came up with a few links:
-- http://millingaccessories.biz/2015/05/10/atlas-milling-machine-marvin-dividing-head/
-- https://www.ebay.com/itm/ULTRA-Marv...D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
-- http://www.practicalmachinist.com/v...-makers-dividing-head-us-made-seattle-210265/
The dividing head had been modified (not permanently) with an external gearing system which effectively changed the input/output ratio from 40:1 to 12:1. It also has a collet adapter for the cutest little collets I've ever seen, a 1/4" Levin D collet (which based on Levin's website, goes for $365 for that collet alone...), a matching collet draw bar, and a spindle thread protector.
I tore the whole thing down, and cleaned and oiled it. Looks like it's had very, very little use over the years. And whoever had it before me took extremely good care of their tools; not a speck of rust on anything. It's fully functional with little backlash in the gear train. It's missing two dividing plates and the sector arms, but appears to be otherwise complete.
Anyone know anything else about it? Like what's the spindle taper?
Based on some of the other equipment/tooling that came with the lathe, I think the previous owner used it to make small involute gear cutters for clocks or watches.
All the best,
Jeff
JRaut
Newbie
Mar 9, 2018
12
Likes
11
#2
Bueller?
Bueller?
I'll give this another day or so then cross-post to the Atlas group, seems it may have been targeted towards Atlas lathe and mill owners.
34_40
Dazed and Confused
Nov 2, 2013
756
Likes
232
#3
I won't have any of the info you seek but I just wanted to say that's a gorgeous piece of work. Looks like it can be externally driven?
brino
Jan 2, 2014
3,461
Likes
3,487
#4
Isn't there something marked right here:
or is that just the serial number?
I cannot make it out.
-brino
JRaut
Newbie
Mar 9, 2018
12
Likes
11
#5
Thanks! That aluminum arm you're seeing is actually a modification made by the previous owner. I have it pivoted out of the way, but it swings in to mesh up with main crank arm. The gearing basically rotates the main crank 3.33 times per revolution of the modification shaft (if that makes sense). So no external input available.
Correct, that's just the serial number.
I did find a product line catalog from Marvin hosted on VintageMachinery.org with a little bit more information. Looks like the taper is a MT2, and originally came with a tail stock and two more index plates.
The images suggest that there was originally a nameplate on top, which is long-gone on mine.
[6]
[5] [7]
