- Mar 12, 2013
- 302
I recently bought International Harvester Model LB engine. While moving it the flywheel got moved and the valves wer stuck. The intake rocker arm stapped at the end nearthe push rod. I think ive found a source of a reproduction but I haven't given up on looking for an original.
The question I have is Im not getting spark from the magneto . I took the cap off and used the tester on the end of of my index finger to check for spark by touching the brass nub on top of the coil. Yes I'm Crazy!
The points look clean but I did run a point file across them. I'm assuming now that the coil may be bad. Is there a way to test the coil to see if that is bad.
This engine was on a old cement mixer and there is a hole about the size of a quarter it the top of the water hopper. Any thoughts how to repair this?
