- May 22, 2019
- 89
I was going to post this in the electrical power knowledge but I think this is the better spot.
So I’ll just post my question here.
Like the title says, I have a 300a inverter tig welder and vfd that will be powering the new motor for my mill nearby, in very close proximity. Do any of the electrically smart or persons with experience see a problem in my future?
Common sense tells from everything I’ve read it not a bad question to ask.
If There is the possibility, which is more likely to cause the other to have problems?
Common sense also tells me the tig welder is going to be the one causing problem with the vfd, but I can see how the vfd might cause problems with the welder.
I’ve googled and didn’t find much.
But like I said, this isn’t even a problem at this time,I just want to know if there’s a good chance I will have problems, and since more and more people are using them in the home shop I think it’s a very good question?
