I believe he was disappointed with the minimum size it would hold.It's got to open more than you have it shown. There are gear teeth on the guides. It looks like the knobs are travel locks and the knobs on
other side are the pinion gears to move them in and out. With the number of teeth remaining it looks like there is a lot of room to move.
Gary
Likely for a cylindrical grinder. You could make brass caps to fit on the posts to reduce the size it will contact.
Gary
I would think the hardest part of modifying it to fit a lathe would be getting the Height and lateral alignment just perfect so all three fingers came in concentric to the center of the lathe rotation... (Im not sure I said that right, but... Im a newbie).
