- Jan 1, 2018
- 1,110
Thank you.You're definitely sucking now!!!
Around here, that is an exceptional deal. Nice drill presses usually go for much more than that. Congrats!My name is Michael, and I have a problem! Last weekend was the sliding table saw for $500. This weekend is a variable speed drill press for $200.
I found this on Craigslist an hour and a half after it was posted. I spent a good half hour trying to talk myself out of it... with no success... it was still posted. When I called the seller and asked if there was anything wrong with it he said: "It's old". I drove by the ATM and when I got there he told me it was about 18 years old and I probably wouldn't be able to get parts for it. I cranked through the low and high speeds and the spindle was nice and smooth. I could detect no play in the spindle when grabbing it and trying to jostle it. I has spent all of its 18 years in his wood shop and only has a single mark of shame on the table. It does look as nice in person as it does in the photos, if not better.
I have 2 vertical mills and this will be my 4th drill press. I have a 25 year old HF 16" drill press from back when they were mail order only. I have a 14" Chinese drill press given to me by my brother in law. And I have a 13" Walker turner I spent $50 on which is just like the WT my father had when I was growing up. The WT is a bench model that someone put a long column on to make it floor standing. I think I can most likely get $200 out of the 14" Chinese drill press. I will put the new Delta in the metal working side of my shop and move the 16" HF to the woodworking side of my shop. I don't think I will be able to part with the 13" WT... it is by far the smoothest running of the bunch. I will probably chop the column down to to a bench height colum and stick it in my reloading room under the pretense I might use it there some day.
Yes! I have a sickness... but really how can anyone pass up a 16.5" variable speed Delta drill press for $200?????
Mike, how does the hi low range work? I wish my big ol Rockwell Delta reeve drive had that low speed.My name is Michael, and I have a problem! Last weekend was the sliding table saw for $500. This weekend is a variable speed drill press for $200.
That is a VERY sweet drill press! From what I have read I concur it is probably a stronger more industrial design. I can tell from your picture that it is from the era of higher quality Delta/Rockwell tools.The 15" head on my UniDrill has what I think was the earlier reeve drive where it doesn't have the springs like yours and there is no intermediate like yours. The motor has a reeve pulley and the spindle has the other and there is this mechanical lift and lower mechanism that raises and lowers opposite pulleys. Mine the arms on the motor reeve pulley were bent from dodo's messing with it while it was not running I think. I don't work wood, so even at it's slowest 450rpm and 4700rpm tops that's faster than I like for steel. Just about everything else I love about the UniDrill, especially the huge cast iron table with T-slots. Even though they seem to be an odd size.
