[4]
Jacobs chucks
[3]
[10] Like what you see?
mf294-4
Apr 22, 2012
75
Bought a 18N and need to remove the arbor that is in it. Is there a thru hole in the chuck? Looks like there is a hole. I had it in a press and no success. Need more press? 2nd chuck has 3/4 16 threads, does anyone make a r8 arbor for it?
GrayTech
Active Member
Jan 18, 2018
110
The 18N has 4JT taper and can get quite stuck. Maybe try warming up the body a little and then more press as you put it.
Sent from my H3123 using Tapatalk
ddickey
H-M Supporter - Gold Member
Apr 21, 2016
2,158
What size MT?
If a 5 you can get it out with a vise.
Bob Korves
H-M Platinum Supporter ($50)
Jul 2, 2014
6,685
If there is not a hole visible in the chuck, you can drill one. Doing so will not damage the chuck if done properly. It is usually pretty obvious if there is a hole or just a dimple in the bottom of the chuck. You will be able to see the arbor through the hole, 1/4 - 1/2" deeper, using a good light.
Downwindtracker2
Sep 5, 2014
411
Chucks wedge off, there is a slot between the two tapers. I've made the wedge with an angle grinder, but you can buy them already made. My mild steel ones weren't all that good, but did work.
Janderso
Jeff Anderson
Mar 26, 2018
1,487
The wedges are the way I have been using and all instructions seems to go that direction.
What do you do with the hole?
Drive it out?
[5] [7]
