- Mar 20, 2013
- 153
I just read wrmiller’s post on his new TMX 5C chuck that a friend gave him(lucky dog!). I’ve been thinking about getting one (Tool-I-Tus?) But, I already have a Jacobs flex collet chuck. I would think the 5C would be a little more rigid and accurate than the flex collets. The Jacobs flex set that I have show little wear but it seems to me that relying on a rubber material to hold the collet splines might lead to some flex. Most of the time I’m chucking up smaller pieces and have to make and use a short spacer of the same diameter as the piece I’m chucking up in order to completely fill the collet’s length. Is that the case with 5C collets? Or, can you insert part way into the collet and it will hold? I guess the thing I like about the Jacobs collets is that each collet has a range of .100 so I have 11or 12 collets and that takes me from .100 up. Let’s see, 12collets or 35 to 57 collets? And I understand that there’s not much range with the 5C collets, is that right? That’s a plus for the Jacobs. So, enough babbling, anyone out there have experience with both the Jacobs and a 5C chuck that can enlighten an old fart?
