Does anyone have any knowledge about this little gem? mounting instructions , instructions for use? any and all information would be useful at this point in my investigation
I have read alot about it when I pop the ring it will not turn to loosen the nut no matter how hard i turn i tried lubricating everything. What can use to turn the wheel and not break it?
There is almost a half turn of movement to use the ring as an impact tool to tighten and loosen the collet nut. I believe that the correct direction to loosen is to impact the top of the wheel towards your body.
