A little more info: The belts I'm looking for are the high speed, thin, flat belts that run on the crowned pulleys between the motor and spindle. They are very similar to the belts found on tool post grinders.
I agree with Voca, NAPA will most likely either have it stocked or will get it in a day or 2. Other then that it kinda sounds like something a vacuum repair store would carry (tool post grinder sized) depending on length.
