Kondia owners? Clausing Kondia standard head manual machine owners?
Lower the quill about 1" and lock it. Now you can troubleshoot the kickout linkage. The button on the upper right should push down much further than you did in the vid. Once you get everything freed up the feed lever should lock. Try pushing down on that button and prying up on the threaded rod at the same time. Don't forget to lock the quill about an inch from the top first.
The quill was locked about an inch down during this video
Yes, they are very close, and many parts on a Kondia will interchange with a Bridgeport. That is part of a detent for that button that the quill pushes up on.
This is what these parts should look like for the feed lever to engage. Mine is sticky too.
yes the plunger under the scale that knocks the engagement back was just really sticky. Seems to be working OK now.
Great! I was going to suggest taking the scale off to get a better look at that.
