- Feb 8, 2014
- 11,138
I would expect some voltage when turned on. That's how the rotor is locked. If it under proper control of the Kanalog board, the voltage should increase as you attempt to turn the motor shaft, thus trying to maintain position.
As far as the fans, they should come on when the drives are powered up. I would rewire the relays so they are under your control. Originally they may have been under the control of the Fagor controller. In my cabinet there is one fan that comes on at system power up for general cabinet air flow, the two servo drive cooling fans are wired into the same relay that powers up the the drives, thus only come on when the drives are powered up. The drives themselves do not control my fans.
