Lathe back gears
Camnefdt
Jun 21, 2018
41
Hi all
So I've done some reading inside the south bend lathe operating book and it talks about the back gears on the head stock being used to get slower operating speeds.
Can somebody perhaps elaborate a little more on how this system is meant to operate?
I will attach a pic of my head stock off the colchester I just got but when back gears are engaged, the head stock is completely locked up.
Are both gears on each side of the pulleys meant to be hard fastened to the shaft? I do plan on stripping the whole system over the weekend to clean up and check up on the condition of bearings etc but just an idea of how its suppose to work would help
Camnefdt
Jun 21, 2018
41
Never mind, found it already hahaha just shows that looking for 1 more second (literally) can make all the difference
markba633csi
Apr 30, 2015
4,447
Yes the all-important pin :D
How are your gears? They look pretty good from what I can see
dlane
Sep 27, 2014
3,073
South Bend have a pin that pulls out to disengage the bull gear from the pullys.
Have pics of your lathe ? We like pics
Camnefdt
Jun 21, 2018
41
There's 1 or 2 with tiny chip on a tooth or so but all in all they seem good condition.
Everything is covered in some kind of horrible lubricating 'stuff' which i can only think of as being like a copper compound spray that was sprayed all over everything
Camnefdt
Jun 21, 2018
41
This is the full lathe, colchester britannia which, as best I can track, was made between 1920 and 1930.
markba633csi
Apr 30, 2015
4,447
Must be a rare one, no information on that model I can find, only Triumph and Master models of that era
Smithdoor
Dec 23, 2012
435
Looks great
Look big for a pin , sliding knob or some other in Gage the large gear.
Typical from time of building it was simple and basic
Dave
Sent from my SAMSUNG-SM-J320A using Tapatalk
Smithdoor
Dec 23, 2012
435
Using back gears and the blet gave good power at speed and then blet give good finish on last pass
Dave
Camnefdt
Jun 21, 2018
41
Looks great
Dave
1530072518256725924323.jpg the back gears themselves are on an offset bushing with a dial that you pull out, then turn and has a detent to clip into position, but to disengage the gear from the pulleys, it has a little switch type thing on the side of the biggest pulley.
Smithdoor
Dec 23, 2012
435
The big gear on the spindle
Looks great
Dave
View attachment 270634 the back gears themselves are on an offset bushing with a dial that you pull out, then turn and has a detent to clip into position, but to disengage the gear from the pulleys, it has a little switch type thing on the side of the biggest pulley.
AdBlock Detected
I've Disabled AdBlock
