I was lucky enough to use my neighbors skid steer with forks, so one fork ran down the entire length with 2 straps spread apart.
I don't remember the model, it was a tracked Deere, I had just enough clearance for my high cube container. Stand was ready at the opening, had my son glide it down, then used turtles to get it in its resting place.I used Dad’s skid steer to get it to the shop from the truck but it’s a large frame machine (JD 332D) and is 6” too tall to make it into the shop.
I told him he should buy a smaller one for me to use sometimes but he didn’t go for it, LOL.
I helped move a lathe that weighed about 1300+ lbs. I have a 2 ton engine lift and a come-a-long. Not my lathe , helping a neighbor. Lathe is top heavy so lifting it level helps. After lifting off the pallet several inches I hooked the low end to the hoist boom. Cranked the come-a long and leveled the lathe. Set it down on the metal bench that it came with.. Took about 45 minutes.Here’s my current configuration.
It’s balanced and doesn’t try to alligator roll.
Nothing is being pinched.
The bottom cross board is oak.
I added a little block on top of the bottom piece so it can’t slide too far towards the tail stock.
The spindle strap isn’t bearing any weight.
ETA: I do have to take the right leg/foot of the hoist and go on the right side of the right cabinet as the measurements in the manual were wrong and it's only 40.25" between the cabinets rather than 43.75" and the legs/feet of the hoist are 40.75" wide
ETA 2: I wish I had a spreader beam but anything trustworthy appears to be $500+
View attachment 578845View attachment 578846
Can you remove the screw from the inside and move the spacer to the other side of the latch bar?
