I think fg.. is correct. You have to be very careful when you do this sort of thing.
Changing HP will also change the torque for the same speed, and Torque will be
your enemy if you apply more than your gears, equipment is able to handle.
If I remember correctly;
HP = Torque * RPM / 5252 or Torque = HP * 5252 / RPM
Run a spread sheet of this basically formula and you will what happens when
you have speed range say 50 to 1500 with varying HP size motors. You
will get the picture.
I have made gears for my little 109 craftsman, and went thru the calculatons
and can use the lathe, but I have to take much smaller cuts so as not to
overstress the components. I had bought a few gears on-line, only to discover
that the 'seller' was a little less than forthcoming as to quality and condition.
I'll just make my own from now on. My little lathe works, but I do baby it. After
all its a 'baby lathe' and I do this as a hobby, not for profit.
Have fun playing
