[4]
Lathe Tailstock Sliding Tap/Die Holder
[3]
[10] Like what you see?
JPigg55
Nov 8, 2012
721
Likes
215
#1
With all the threading I've been doing of late, I'm wanting to buy a threading tool for my machines.
Both my lathe tailstock and milling machine are MT2 tapers. I found this one:
http://www.neilsniche.com/lathe-tailstock-tap-die-holder.html
I was wondering if anyone else had one of these and your opinion of it.
Any other recommendations would be appreciated too.
coffmajt
H-M Platinum Supporter ($50)
Sep 25, 2013
201
Likes
182
#2
I made a die holder for both round and hex for my south bend lathe, and it works just fine. For taps I just use a drill chuck in the tailstock with the tailstock unlocked to the bed -- Jack
mksj
Jun 12, 2014
1,977
Likes
2,399
#3
I purchased one those for a MT3 tailstock. It works well, but with a few considerations. Overall it is well made and a reasonable price, but I ended up modifying mine quite a bit. The die holders are specific for round dies so if you have any other type, most likely they will not fit. I ended up making several new die holders. The tap holders 0-1/4" and 1/4-1/2" are convenient and good quality (they now offer a 1/2-3/4"), if you were to make your own, probably would need to buy some T taps and remachine them. I did not care for the provided single tap handle, it is long as to rest against the carriage for power tapping. I drilled and tapped two hole and added a T handle that clears the carriage. I also made my own guide/hoder that fits into a chuck and only uses the tap heads, which I also use in my mill. It uses the same tap and die heads.
So overall a good starting point, but may need a bit of modification to suit your needs. Now that I am a bit more proficient at the lathe, I would probably make my own, but it is nice quality and reasonable for what is offered.
Mark
Additional dies through 1.5", additional T handle holder with guide rod that fits into a chuck. It use the tap heads and dies.
Added a T handles to the stock setup, works very nicely for manual tapping.
Machined a smaller T handle that fits into the chuck, uses either tap head or dies, also works well in the mill
Large 1.5" die holder that fits the MT3 guide rod.
wawoodman
himself, himself
Mar 19, 2011
931
Likes
711
#4
Making a set of those was one of the first things I did on my lathe. It was a great feeling!
Hozzie
Sep 8, 2016
136
Likes
89
#5
I have that exact one. Works well and I am happy with it.
mikey
Dec 20, 2012
4,667
Likes
5,059
#6
I agree with the others - this is a good DIY project if you're so inclined. Simple turning, knurling, boring or reaming and taper turning. You'll learn a lot on this one.
D
Deleted member 43583
Guest - Please Register!
#8
I have a Neils Niche set.
The tap holders appear to be low end from China.
My view is the set is a little rough in terms of finish but it functions well and provides a base to move forward with. I have the stock in hand to make some additional die holders as needed. I will likely replace the tap holders as the aggravation of using them increases each time I pull them out.
As Mark pointed out, it is a good starting point. Keep your expectations in check.
ddickey
Apr 21, 2016
1,888
Likes
937
#9
I made my own too and it works very well. I can use round or hex dies.
Creativechipper
H-M Supporter - Silver Member
Jul 9, 2018
202
Likes
69
#10
I am thinking of making one of these, any pictures or drawings of the ones you all made?
Things you like or would change now after using it for a while?
Thanks
ddickey
Apr 21, 2016
1,888
Likes
937
#11
Round or hex dies?
Creativechipper
Jul 9, 2018
202
Likes
69
#12
Round with lil half cuts all the way around Blue point TD2400 old school set.
bill70j
Nov 9, 2015
88
Likes
158
#13
Thanks
I built one for round and hex dies also. Works as expected.
YouTube creator Halligan142 did a 3-part series on making one of these. It's worth a view, in my opinion. He gives dimensions.
coffmajt
Sep 25, 2013
201
Likes
182
#15
Here is a die holder for both round and hex The shaft it slides on has a mt2 end and is 8 inches long x 5/8 diameter. The holder made from 1 1/2 inch diameter cold rolled and is 3 inches long.
DiscoDan
Jul 16, 2018
262
Likes
143
#16
I have one of Neil's setups. I used it twice tonight, once on a practice piece and and again to fix the threaded handle that I broke the threaded part off of. Neil gave me ample warning by phone that you can only thread so far before you bottom out in the die holder but my feeble mind forgot. So the tool came in handy to fix itself. I may have to try and make holders for my hex dies. Happy overall and Neil has been great.
mcdanlj
Active Member
Aug 24, 2018
74
Likes
38
#17
Here's the watchlist to make it easier to find...
[6]
[5] [7]
