lathe tool storage racks
U
umahunter
Forum Guest
Register Today
Searching ideas let's see what ya got guys :)
rgray
Nov 26, 2012
1,307
My attempt at organization.
The ones on the outside are on hangers made from snowmobile Hyfax (slide rail plastic slides).
chuckorlando
Nov 24, 2013
1,791
I use single screw driver holders on some peg board. The cutters are i the box though
10404515_943244005690559_1646324093974944731_n.jpg 10301415_943242835690676_3471652503674307029_n.jpg
Holescreek
Nov 10, 2013
837
I have steel slatwall on two sides of my shop behind the machines so I make my own tool racks out of 20 ga sheet metal that fits into the slots. Bend 'em up and spot weld 'em on.
A circle template made of plywood makes it easy to plasma cut holes in sheet metal for the R8 stuff.
David S
H-M Platinum Supporter
Nov 18, 2012
1,339
I don't have a lot of room. Quick change tool holders on white shelf above back shield. Chucks, keys, allen wrenches, far right corner. Taps, center drills, special bits and metrology in small cabinet below lathe.
David
Cheeseking
Oct 30, 2012
918
I use al extrusion. Tried both sheetmetal (.090 aluminum) and nylon slats. Honestly they both work equally well. Nice thing is you can use multiple surfaces of the extrusions. Very easy to reconfigure. I was somewhat concerned about cantilevering etc but its solid as a rock.
Use it on my pegboard too
ImageUploadedByTapatalk1415805989.366605.jpg ImageUploadedByTapatalk1415806007.008131.jpg ImageUploadedByTapatalk1415806062.071452.jpg
Fabrickator
Jan 22, 2014
578
I see all of the different designs here and thoroughly understand "limited space" with my working machine shop in half a 2-car garage, but I warn people to never store ANYTHING above your lathe. To the side, the back, underneath, whatever. But, definitely not above the spindle/chuck or anywhere that something could possibly fall into spinning parts. It's tempting, empty space and convenient, I get it.
Safety First! Check my Signature. :think1:
Tool-in-the-Box
May 7, 2014
165
I had nice white pegboard behind my lathe. Had all the tools on it, nice and neat. Looked great. Then I used the lathe for a bit. If oil was red it would have looked like a crime scene.
AdBlock Detected
I've Disabled AdBlock
