Same dialThen maybe the new threading dial is a metric version. You could count the teeth on the new vs the old thread dial gear.
Lead screw was bent pretty severelyI didn't realize you replaced the lead screw. I thought it was only the cross slide..
I will do that tonight after work. I was going to do it yesterday, but had prior obligations.Just to know for sure, why not measure the lead screw pitch? Measure over 10 threads and divide by 10. Once you measure it, then you know it for certain. One less variable in the puzzle. Instead of 4tpi, it could be 6mm? At first glance, they look similar.
Is your half nut handle traveling the same distance every time?Ok, checked lead-screw and dial, I did not measure distances per revolution. It is 1/4” per thread - so 4tpi?
Here is a vid from doing some testing.
same each time, New machine - had a faceplant, but all parts needing replacement have been replaced. Half Nut clamp is good, dial gear is good, new lead screw same TPI (measured)Is your half nut handle traveling the same distance every time?
If the half nut gets worn just right (just wrong?) it can engage on the top of the threads well enough to cut a thread out of synch.
Has this been cleaned and inspected for damage, wear or debris?
