Leblond Dual Drive Just Because
David M
May 2, 2014
75
I picked this up recently and (as usual) got the wrenches out before the camera. I have the compound/cross slide and tapering attachment off already, and it also came with a 12" 3 jaw chuck. I took a peek inside the headstock, belts are all shot but gears all look good. It has oil in it and the pump is working. There is a tag on the belt cover that says "Property of United States Air Force" and since I don't think Uncle Sam buys used equipment I am assuming they were the original owners. I put a dial gauge on the saddle and ran it back and forth, shows almost no wear in the ways. Gonna give it a good cleaning and a new coat of paint.
calstar
Sep 26, 2013
403
That is one beefy looking lathe, very nice. What does dual drive mean? The obvious answer is two motors but I'm not familiar with that lathe or what the term means.
thanks, Brian
David M
May 2, 2014
75
One motor. It has 12 spindle speeds ranging from 28-1800 RPM, the spindle is gear driven in the 8 lower speeds and belt driven in the top 4.
wa5cab
Downloads Moderator
Staff member
H-M Platinum Supporter
Dec 25, 2011
7,978
"Dual Drive" could also refer to the fact that it has separate drives for threading and for other carriage or cross slide operations.
David M
May 2, 2014
75
The good cleaning and new coat of paint I had planned is experiencing a little mission creep. After removing the apron I found that over time a few chips had worked their way inside, the gears all look good but a couple of the ball bearings were a little rough, off the shelf parts, so no big deal. A bigger problem is that the internal key in the bore of the apron drive gear is all but gone. I have not checked with LeBlond but suspect that a replacement gear from them will be cost prohibitive. I have an idea of how I can fix the old one but haven't done anything yet. In the mean time, flood coolant is something I will never use, so I decided to make some changes to the tray. I cut the center section out and turned it around so that the drop will be facing the front and should make cleaning the pan out easier. I am also going to cut out about half of the depth. IMG_2108.JPG IMG_2109.JPG IMG_2110.JPG IMG_2111.JPG
David M
May 2, 2014
75
What was the back is now the front, lots of welding and grinding left. I think I'm going to like it. I hope I'm right. IMG_2112.JPG
David M
May 2, 2014
75
Not quite ready to work yet, but close. I took the power box off of the back because I plan on putting the lathe up against a wall and I wont have access if I need it without moving the lathe. I ended up making a new key for the apron gear, but that was the only repair it needed. Changing the chip pan was some work but now that it is together I am glad I did it. Going to require a little musical chairs in the shop in order to put it where I want it, I the meantime I'll just run a cord to the phase converter.
mzayd3
Feb 10, 2014
366
All that work in less than a month? Good for you! Looks nice!
gr8legs
Oct 31, 2014
303
Very nicely done! I especially like the reconfiguration of the chip pan. Very practical indeed!
Stu
David M
May 2, 2014
75
Nice work! You really ready to get her all dirtied up?
Thanks Stu, the chip tray is working out well, I'm glad I took the time.
Thanks also FOMOGO. I am already pretty happy with it. The rigidity to be able to use things like parting tools and negative rake cutters is very nice.
AdBlock Detected
I've Disabled AdBlock
