[4]
Left Hand Thread Pipe Taps???????
[3]
[10] Like what you see?
JimDawson
Global Moderator
Staff member
H-M Platinum Supporter ($50)
Feb 8, 2014
7,457
My neighbor picked up a few boxes of stuff at an estate sale. One of the boxes has a few left hand thread pipe taps from about 1/8 to 1/2 NPT. These are standard NPT taper. In 50 years of being around this stuff I have never seen a left hand thread pipe tap before.
Anybody have an idea what these might be used for?
JimDawson
Global Moderator
Staff member
Feb 8, 2014
7,457
I just did a web search for them, looks like they are commonly available. Learn something new every day.
RJSakowski
H-M Supporter - Gold Member
Feb 1, 2015
3,744
I have an ancient steam autoclave. The stand for it is made from 12 sections of threaded 3/4" pipe, like so:Pipe Stand.JPG
The only way this could be assembled would be if both left and right hand pipe threads were used. Idon'tknow if they are tapered or straight pipe threads though.
Bob
GK1918
Nov 21, 2010
1,594
Very common with gas lamps back in the day so there would not be an ugly unions visible.
My mother in laws house still has the gas pipes no unions. I too have those, but the rare
thing is finding left dies. .....
Eddyde
Bronze
Oct 13, 2014
1,430
when I worked installing A/C central air over 35 years ago we would use a left right fitting for gas lines in the attic where you could not use unions. it would join to pieces one left hand the other right.
Here in New York City it is illegal to use unions anywhere in a gas system so left-right connections are common. They are usually sold as a set consisting of a 6" nipple and a coupling each with one end left hand treaded.
D
Deleted member 17524
Guest - Please Register!
You can take this as Gospel, if there is a Tap, there is a Die to match.
"Billy G"
JimDawson
Global Moderator
Staff member
Feb 8, 2014
7,457
"Billy G"
Yup, it seems that most to the major vendors have them and you can buy right/left pipe nipples. You would think that as long as I have been around industry that I would have run into them before. We just keep learning.:eagerness:
KBeitz
Apr 17, 2018
456
Steam manifolds was made from cast iron. 10 pipes each.
One end was left hand threads.
[6]
[5] [7]
