Permatex ultra grey. It is the equivalent to what the auto manufacturers are using on oil pans and rear end covers. You can't beat it. Just make sure the parts are clean before assembly.
The local Menards had Ultra Grey so I got some of that. Then I realized I have a rubber gasket I took off and as i understand I should use a gasket sealer with a gasket. Or I guess I could just not use the gasket. I'm heading to Grainger today so I could pick up some proper gasket sealer. Anyway when I took off the bottom cover it was full of a white tacky substance, all the bolts as well.
