List of gears in orignal Logan 200 gear change set?
AmericanMachinist
Mar 3, 2020
195
Has anyone seen a list of what comprises a full set of Logan 200 gears? I'm trying to verify which gears should be in duplicate, particularly. 32T I believe is one.
Thanks
Yes. PDF File Page 39 in the PDF of the Logan manual on the 200 Series in Downloads has a list of the ones supplied with the lathes. Including the quantity. This is for the Change Gear model. .
So, you need 17 change gears (6 on the machine + 11 extras). Notice though that you need 2 ea. 36 tooth gears: one change gear
and the stud gear which is not counted in the 17 gear total. The change gear list shows 2 ea. of the 32T gear as well as 2 ea. of the
24T. All the other gears are singles.
That's correct. I guess that I assumed that he had the gears that always stay on the machine.
Not sure what he has, but since he asked for a reading on the full set, I thought I'd point out the stud gear question.
It's on the same shaft as a change gear, but shows up elsewhere in the parts list. The reason I noticed is because it's the only one missing from my gear set.
Lucky you - NOT! :(
