- Apr 23, 2018
- 6,520
The Quorn has more useable range in its tool swing, therefore a broader work envelope. IMHO it's a step closer toward the Cutter Master in that regard. The Deckel does not have much room when the workhead axis is pushed past the travel axis in the direction of feed for grinding certain angles, and the Quorn looks to have more space there. The Cutter Master goes a full 180 degrees.I'm with you on that one. Why do you say the Quorn is more capable?
