OK, my next 820 question, now that we've solved the back gear/direct gear issue.
The Logan chart is not precise on where to oil the apron. Item 8 says "remove set screw and fill this oil well so that when petcock set screw (9) is removed, oil just drips out." I think the set screw is the one my yellow arrow in the first pic points to, but when I get oil in there it drips out the bottom of the apron; I can't tell exactly from where. I think the petcock set screw is the square bolt pointed to in the second picture, actually there isn't another likely candidate, but it isn't a petcock and when I remove it no oil drips out. Help please?
TIA,
Tim
TIA,
Tim
